PKT 7.5 ו MGCAMD
- marcelos
- הודעות: 1028
- הצטרף: 11 פברואר 2005, 09:54
- מיקום: קרוב, בסביבה
- dudutr
- הודעות: 1440
- הצטרף: 25 ספטמבר 2006, 18:09
- marcelos
- הודעות: 1028
- marcelos
- הודעות: 1028
בדיוק...רק שאיני מבין בזה ורציתי את עזרתכם כדי לא לדפוק את MG עוד יותר...
זה התוכן למי שיכול לעזור:
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 00 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
U: { 05 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
G: { 09 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 04 } 01 05
# network ecm timeout in seconds
K: { 30 }
# newcamd dead routes connect retry, sec
Q: { 30 }
# network shares priority
# 00 gbox, newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd, gbox
# 02 newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 }
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 00 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 02 }
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 00 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E:) time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 00 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 07 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { ff }
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 11 }
# EMM messages
M: { 01 }
# ECM messages
C: { 01 }
# AU
A: { 00 }
# 04 enable TPS au
U: { 05 }
# 01 files in /tmp
T: { 00 }
# 08 gbox netclient
G: { 09 }
# 00 disable
N: { 04 } 01 05
K: { 30 }
Q: { 30 }
P: { 02 }
# 01 neutrino
# 02 enigma
# 03 relook
O: { 00 }
# 01 show emu ecm
S: { 00 } 80
# 00 off
# 02 log to console
L: { 02 }
E: { 00 }
# 00 Off (default)
H: { 00 }
# 00 No (default)
R: { 07 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
D: { ff }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 11 }
+100 to 1W
+120 to 19E 7E
+100 to 1W
+120 to 19E 7E
- dudutr
- הודעות: 1440
- marcelos
- הודעות: 1028
- dudutr
- הודעות: 1440
- marcelos
- הודעות: 1028
- marcelos
- הודעות: 1028
כל הבעיות נפתרוווווו
סוף סוף......
והפתרון: בעית מקום - מחיקה מה שאפשר...אני תכלס אין לי מושג מה אפשר, אז מחקתי את כל השפות זרות חוץ מאנגלית ופורטוגזית... מעניין אם אני יכול למחוק את כל הפלוגינים ידנית דרך FTP... כמו הDVD BURN...וה SUTITLE שלא יהיו בטוח אצלי בשימוש...
בקיצור עכשיו הכל נפתח מהר כולל הSOFTCAM...עכשיו אני רגוע...שבוע לא קל עבר על הממיר שלי...חחח
תודה למיקי התותח ולאמיר הגדול שעזרו בכל הדרך...
בנוסף כל חברים DUDUTR AHGI וכו'...
סוף סוף......
+100 to 1W
+120 to 19E 7E
+100 to 1W
+120 to 19E 7E
