למי יש צורב nextwave?
hulday
- הודעות: 1150
- הצטרף: 15 מרץ 2004, 17:57
hulday
- הודעות: 1150
hulday
- הודעות: 1150
הנה שאלה ששאלתי:
i try to update from 1.04 to 1.05 with funcard 6.
first cars - all OK !!
2nd - ok until its come to 510/515, and stpo !!!
what to do ??
והנה התשובה, אולי זה יעזור לך:
hi when the count stops on the second card wait 1 minute then press exit ,it should say saving info then press exit again and wait until the menu appears.press exit again and the menu should go away,now press the standby,(do not switch the receiver off at the mains,this will wipe the cam)remove the last card without removing the cam and press standby again to bring the receiver back on.enter the cam menu ,press settings then press defalt keys and that should do it .if anything goes wrong during this proccedure then eject the cam and u will abort everything do not switch off at mains .good luck
ושוב אני:
the only butten that work when the counter stop is the standbuy.
i switch off and than on again:
its show in the menu that the xcam is now 1.05, but
its never finish the counting. its mean thet the cum is now upgred ok ??
its happend to allsaw whe i am update the softkey with funcard.
why ???
this is how its supposed to work ??
ושוב תשובה:
yes with some receivers the count doesn't finish,just make sure u hit default key in menu after u switch the receiver standby back on.the fact that your cam says 1.05 is proof that it worked and if u pressed default key your home.bye
what to do ??
ושוב אני:
why ???
ושוב תשובה:
7eva
- הודעות: 1580
