FastSatFinder 0.98 - dll plugin
yoramile1
הודעות: 6125
הצטרף: 02 ינואר 2004, 20:47
Has thanked: 6 פעמים
שליחה על ידי yoramile1 »
להורדה
TERMS OF USE
This software is provided "as is", without any guarantee made
as to its suitability or fitness for any particular use. It may
contain bugs, so use of this tool is at your own risk. We take
no responsilbity for any damage that may unintentionally be caused
through its use.
INSTALL
Unpack and copy FastSatFinder.dll to directory ProgDVB.
USING FastSatFinder 0.98
MODE 0:
1.Run ProgDVB.exe
2.Select Plugins -> FastSatFinder ->Start.
3.Choose the necessary satellite and press Find>.
MODE 1:
1.Run ProgDVB.exe
3.Input transponder frequency ( 3400 -7100 or 10700 -12800 Mhz ),
polarity, symbol rate ( 1000 - 45000) and click Find>.
For exsample: 12245H27500
5.Check signal. ( The signal is constantly updated! ).
Note: if you are using C-band, then also select C-band in ProgDVB.
Remarks
1.Double-clicks the left mouse button to increase (to reduce) the size
of a signal quality window.
3. Press :
'enter' - find;
'space' - back;
'm'- to cnange mode or mute;
'alt+F4' or 'Esc' - exit.
Licensing
If you are interested in redistributing FastSatFinder, either in original
or modified form, or wish to use source code in a product,
please send e-mail to sat@projektas.lt with details.
Reporting Problems
If you encounter problems, please visit http://www.sat.projektas.lt
and download the latest version to see if the issue has been resolved.
If not, please send a bug report to: sat@projektas.lt
"Samsung QE55Q80T 4K QLED 55
Zgemma h7s
Vu+ Ultimo 4K
Vu+ Uno HD
TeVii S472 DVB-S2 PCIe
