hi all we have had a lot of talk on these forums about ir2
the truth is that people in australia have been so use to ir1
that ir2 seems to be uncrackable.but let's talk about that.
1 ir2 stream is on a different pid and some units have to have the pid changed to log
2 units will not log on correct ir2pid with a ir1 card inserted
ir1 card will change the pid
3 you can only log raw data what to do with the data
4 data needs to be written to the card in a different ie signature
5 current programs won't right the file to the card in a manner that the card would reply with the right signature (no service)
so we have a problem well not really.
ir2 4.1 works on a new set of rules
1 the card has 4 hmks
2 the card has 4 pmks
3 the card has 4 mks
4 00 10 20 30 all work together to provide the signature
s that the card provides service
i will not explain how to get the info from the log but it is not that hard if you are ok working from a bin file
the problem with ir2 is that their is not a program that will allow
pro 00 10 20 30 to work together to provide a valid signature
this is the reason that the system has not been cracked
and that current equipment seems to be useless but we all know better now.gold,silvers will still work but the progams and memory
locations to the card will need to be mapped differently
