ג'מיני אימג' 2.10 MOD !
קבצים ולינקים המיועדים ל 7020 ו 7020HD בלבד
yhaddad
הודעות: 1391
הצטרף: 12 מרץ 2004, 21:08
מיקום: מרכז
שליחה על ידי yhaddad »
יצא גירסת MOD לאיימג' ג'מיני 2.10 .
השארתי את ההסברים," מה זה MOD ? " ואיך להתקין אותו למי שעדיין לא יודע :)
Also this time concerns not an image, but a so-called MOD (modification)
And why that?
1. The complete flash is writable
2. Size of an image would be 15 MB, a MOD is only 2-3 MB small
3. Images have to be flashed, MOD to be copied only
4. Several MODs can be installed at the same time
5. The original DMM-image can (have to, for warranty reasons) be left on the box
Before you can install the new MOD, you have to remove the old one:
ipkg remove gemini
How to install the MOD:
To switch between the different Enigmas, we need a tool of which this takes over.
A modified DF is used as “start menu”.
Copy the file "startmenu.ipk" via FTP to "/tmp"
The package has to be installed via Telnet "ipkg install /tmp/start*"
During the installation Enigma goes off for a short time and the start menu should be visible.
In order to install the actual Gemini we proceed similarly.
First copy the package, then install it via Telnet "ipkg install /tmp/gemini*"
As soon as both procedures have finished successfully, simply introduce a reboot and select Gemini in the start menu.
Technical info:
Enigma from 12.07.2005
gcc 3.44 Original CVS
Web Interface: 4.3.2
Blue Panel v1.7
User Info
WLAN Setup v0.7
BLUE Button - Blue Panel
YELLOW Button - Quick-Button (can be adjusted over BluePanel)
AUDIO Button - Audio Selection
TEXT Button - Videotext
RED Button - EPG List for the current channel
2x RED Button - Double Click for EPG Style Menu
GREEN Button – Subservices
Features:
AutoCam: Emus can be linked to Channel/Provider
CamName: Renaming of Emus
Record CIFS: Recording on a harddisk mounted via CIFS (only available if there is no hdd in the box)
Record NFS: Recording on a harddisk mounted via NFS (only available if there is no hdd in the box)
Showing the clock(and only the clock!) can be assigned to the QuickButton
MOD can be moved to USB/HDD/CF and also back to root
New:
- DreamDyn renamed to InaDyn again
- httpd Server
- Cams are switched by gdaemon now, from now on there is DVBSET=1 only
- Skin reedited
- DreamInfo reedited
- News can display “Umlaute” from now on(ä, ü, ö,…)
- NFS/CIFS in Timermenu only, if mount changed successfully, there is a size inquiry now,
if storage capacity in NFS/CIFS mount bigger than 3GB and /hdd mount is bigger than 3GB it will be shown in Timermenu; like always, it functions without a mounted HDD only!
להורדה כאן
