ג'מיני אימג' 2.10
- הודעות: 30820
Gemini Image 2.10 (Dream 7020):
Because of users having problems with installing the MOD, and also a complete Gemini in form of *nfi was on the desire list, here the result!
Technical info:
Enigma from 12.07.2005
gcc 3.44 Original CVS
Web Interface: 4.3.2
Blue Panel v1.7
User Info
WLAN Setup v0.7
BLUE Button - Blue Panel
YELLOW Button - Quick-Button (can be adjusted over BluePanel)
AUDIO Button - Audio Selection
TEXT Button - Videotext
RED Button - EPG List for the current channel
2x RED Button - Double Click for EPG Style Menu
GREEN Button Subservices
Features:
AutoCam: Emus can be linked to Channel/Provider
CamName: Renaming of Emus
Record CIFS: Recording on a harddisk mounted via CIFS (only available if there is no hdd in the box)
Record NFS: Recording on a harddisk mounted via NFS (only available if there is no hdd in the box)
Showing the clock(and only the clock!) can be assigned to the QuickButton
New:
- DreamDyn renamed to InaDyn again
- httpd Server
- Cams are switched by gdaemon now, from now on there is DVBSET=1 only
- Skin reedited
- DreamInfo reedited
- News can display Umlaute from now on(ä, ü, ö, )
- NFS/CIFS in Timermenu only, if mount changed successfully, there is a size inquiry now,
if storage capacity in NFS/CIFS mount bigger than 3GB and /hdd mount is bigger than 3GB it will be shown in Timermenu; like always, it functions without a mounted HDD only!
We thank you all, which participated in the suggestion thread for the Gemini. Unfortunately, many things are not feasible from our side.
Technical info:
Blue Panel v1.7
User Info
WLAN Setup v0.7
Features:
New:
- httpd Server
- Skin reedited
Satil
- הודעות: 588
- הצטרף: 01 מאי 2005, 19:15
Satil
- הודעות: 588
Satil
- הודעות: 588
