CIW Matrix File Converter 2.0 (CIW MFC 2.0)
©MASARE Team - Saoud007
Options avalaible
- BIN to UPD
- UPD to BIN
- Funcard: Fun2, Fun3, Fun4, Fun5, Fun6, Fun7 (BIN & HEX Format)
DROP file option avalaible (BIN & UPD)
Default directory file production: MRFileProduce (created auto if not exist)
Working directory open auto after file creation.
Slide panel added (about software): Clic on slide panel in left to open, Stay out the windows during few secondes to close.
Error Messages:
-No File loaded
-When try to produce funcard from BIN file
-When missing Matrix.LDR file
-When missing ARJ32.EXE compressor
FILE CONVERTER
BIN to UPD & UPD to BIN
1-Run CIW MFC (Matrix File Converter)
3-Load File (BIN or UPD)
4-Select Destination Directory (working directory)
5-Clic on "Convert" button
PRODUCE FUNCARD
1-Run CIW MFC
2-Load UPD File
3-Select Destination Directory (working directory)
4-Select Funcard Type (Fun2 to Fun7)
5-Clic on "Funcard" button
BIN file & CAS Studio upgrade
1/-Run CIS
2/-Select Matrix cam (Reloaded or Revolution)
3/-Select Erase All
4/-Load File (Binary firmware = .BIN)
5/-Clic on Write Button
Cam updated with new firmware
UPD file & Serial Loader upgrade (=dummy card)
Select FTA Chanel
1-Run MRCrypt Revival (choose last version)
2-Clic on button "Matrix Serial Loader Programming"
3-Load UPD File
4-Select COM Port (ticks autodetect Com Port to see all port available in machine)
5-Select Baud Rate
6-In MENU select "SETUP->UPGRADE FIRMWARE" and Press OK in remote control
7-Wait message "Insert card 1 or serial dummy card"
8-Insert Dummy Card and wait 10 secs
9-Select "Dummy card" in menu ci & Press ok.
10-Wait the message "Performing serial download"
11-Clic on "Write" button to start programming
Setting saved when windows closed (\MRSettings\Serial.ini)
After upgrade don't miss to update keys
Select FTA Chanel
Go to CI Menu
Select SETUP
Select SET DEFAULT KEY
Cam reboot auto (if not reboot auto after 30 secs, reboot manually)
Programming Funcard
Procedure Fun2,Fun3,Fun4,Fun5,Fun6:
1-Load Software programmer
2-Select Funcard (2,3,4,5,6)
3-Load Flash_For_Fun2_to_Fun6 in flash for each cards
4-Nothing in internal eeprom
5-Load mr_FUNX_Y in EEprom Ext.1
(mr=Matrix Reloaded or Matrix Revolution firmware)
(X=Funcard Type: FUN2,FUN3,FUN4,FUN5,FUN6)
(Y=Card Number)
6-Burn card
Procedure Fun7:
For 2 External eeprom
2-Select Funcard 7
3-For fun7 load Flash_For_Fun7.hex in flash
5-Load mr_FUN7_1.hex in EEprom Ext.1
6-Load mr_FUN7_2.hex in EEprom Ext.2
7-Burn card
For 1 External eeprom for infinity usb
2-Select Funcard 7
5-Load mr_FUN7_1.BIN (NOT HEX) in EEprom Ext.1
When new windows appear
Clic on "(1)Span"
6-Burn card
For 1 External eeprom for other progger
2-Select Funcard 7
6-Burn card
UPD file & Funcard upgrade
Select FTA Chanel
1-In MENU select "SETUP->UPGRADE FIRMWARE" and Press OK in remote control
2-Wait message "Insert card 1 or serial dummy card"
3-Insert first card, press OK with remote control
4-Downloading start
5-when finish a new message appear "card Downloded, EXTRACT IT & press ok"
6-Insert next card if needed (message appear in screen like "insert card#2 & press ok"
7-DownlOADing fisnish when message "Download complete. Copying image and re-booting." appear
8-Wait 30 secs for cam reboot auto or reboot manually
9-New version firmware appear in CI Menu
Select FTA Chanel
Go to CI Menu
Select SETUP
להורדה כאן
