DCC 2.95
yhaddad
הודעות: 1391
הצטרף: 12 מרץ 2004, 21:08
מיקום: מרכז
שליחה על ידי yhaddad »
גירסה חדשה של התוכנה המצויינת לעבודה עם הדרימים .
תומכת בכל שלושת הדגמים !
new in DCC2.4beta:
box type is recognized by DCC
support of 7020
"experts" configuration added for the paths
view and install startmenu/mods for 7020
button for the webif now in the header
settings removed from tools and put into a new section
settings editor added (very basic)
texteditor for config added
up-/download of large files (terabytes!)
splitting of ts-files for upload removed (as the box can play larger files now)
packet delay for download NULL by default
FTP-module improved
installation of dreamflash-image is now done by a script
download list for recordings is fixed
telnet-module fixed
הגירסה הסופית נמצאת בהמשך השרשור
yhaddad
הודעות: 1391
מיקום: מרכז
גרסת עדכון
new in DCC2.4 BETA2:
- bug in backup of stick-images fixed (endless loop)
- use of internal browser or systembrowser can be chosen in expert-configuration
- installation of bootlogo for 7020 added (in tools)
- ";echo >>> DONE <<<" is added at the end of each telnet-script
- complete telnet and ftp protocoll added in configuration
- faster recognition of 7020
yhaddad
הודעות: 1391
מיקום: מרכז
Lates DCC ver. 2.4 Final
-Movie sorting in Recordings-Editor now supports drag&drop
-Recordings-Editor can be resized vertically
-Error in Config-Menu after changing language fixed
-Error in detecting bigger files in FTP fixed
גרסה חדשה בהמשך
DCC 2.5
גרסה חדשה בהמשך
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Dreambox Control Center 2.6
- Support Embedded Bootmanager.
- Config bootmanager also from external image
- Install bootmanager-skin also from external image
- FTP: Symlinks can be created
- FTP: Attributes now with Multiselect
- Installation of images with plugins, skins and extra-files
(extra-files editor in Configuration/Experts)
- Some bugfixes
גרסה חדשה בהמשך
עודכן ל 2.6a
גרסה חדשה בהמשך
Support DM7025 (Enigma2)
* Recordings
* Backup/Restore Settings
* Editor Bouquets
Newer FTP-Texteditor
* Syntax-Highlighting for Unix-Script, XML, CSS, Phyton uvm.
* Search and replace
* Copy and paste
* Whitespace Linux(LF)- or Windows(CR/LF)-Style
Anzeige versteckter FTP-Dateien
* Einstellbar in Konfiguration/Experts.
Packet Delay f&uuml;r Up- und Download
* Getrennt gesichert und wieder hergestellt.
Verzeichnisse merken in FTP
* Kontextmen&uuml; (re. Maustaste) im Verzeichnis-Panel
* Verzeichnis merken oder aus Liste l&ouml;schen
* Direkter Sprung zum gemerkten Verzeichnis
* Bis zu 20 Verzeichnisse
* F&uuml;r FTP- und Local getrennt
גרסה חדשה בהמשך
New in Version 2.81
- Optional use DNS as Box-IP
- Hidden Password (Experts)
- View hidden files (dotfiles) in the FTP-Commander (Experts)
- Installation DreamFlash removed
- Russian modified
- Portuguese modified
- Fix: Protocol FTP-Transfer
- Fix: Up-/Download Multithreaded
- Fix: Priority Bootmanager 1.Embedded 2.DF
New in Version 2.80
- Show EPG-Data (EIT) in Recordings
- Local copy within the box without detour over the PC
- Adjustment installation of newer images over the bootmanager
- FTP-Textviewer/Editor now on PC-side also
- Some bugfixes (Browser RC, Identify external images and more)
- Russian added, unchecked (Thanks to Vladimir Gavrilov)
- Portuguese added, partial/unchecked (Thanks to Jose Luis Mota)
- German manual as HTML and PDF
HTML: http://www.bernyr.de/dcc/hilfe
PDF: http://www.bernyr.de/dcc/dcc.pdf
New in Version 2.71
- Texteditor: Preselection Syntax-Highlighting
- Bootmanager: List all images on Embedded-BM
- Reboot: Bugfix (deleted settings in the flash-image)
גרסה חדשה בהמשך
New in Version 2.82
- FTP: Date 'Modified' added to Boxfiles
- FTP: Refresh-Button to reload file lists
- Bugfix: Reconnect with other Dreambox-IP
גרסה חדשה בהמשך
גרסה 2.90
גרסה חדשה בהמשך
גרסה 2.92
- Settingseditor:
Handling for Enigma2 fixed
Separators (Segments) inside of bouquets
are not supported (will be removed)!!!
- MP3 Playlists:
Shuffle added (random order)
AlphaSort added (sort by title or path)
- Up-/Download:
Minimize function enhanced
A minimized DCC is still minimized after download
and must restored manually
- Network:
The new network check is canceled (old version) and
now it's possible to disable the check ("No check" in
connection type)
- Some smaller bugfixes...
להורדה
oriel
הודעות: 2035
הצטרף: 25 מרץ 2004, 16:19
שליחה על ידי oriel »
אפשר להחזיר את הלינק בבקשה לDCC 282...(רשמתם שהעידכון באימג לא עובד טוב עם החדש)...
בגרסה 2.90 זה עובד
http://www.bernyr.de/dcc/dcc290.zip
oriel
הודעות: 2035
אם יש לי DCC ישן ואני יתקין את החדש...הוא יתקין אותו עליו?
התקנה זה פשוט לפתוח את ה ZIP לתיקייה. אז אם תפתח לתיקייה חדשה יהיה לך שתי גרסאות
oriel
הודעות: 2035
טעינת אימג' בלי לאבד נתונים עובדת גם בגרסא הזו?
oriel
הודעות: 2035
אפשר בבקשה לינק לגרסא באנגלית...הגרמנית לא נוחה...
אם אין אז אם אפשר לגרסא הכי מתקדמת באנגלית...
תודה!
dpklain
הודעות: 8329
הצטרף: 19 אוגוסט 2005, 00:34
שליחה על ידי dpklain »
אתה יכול להחליף שפה לאנגלית.
בצד ימן יש חלון עם אפשרות לעבור
בין כמה שפות כולל אנגלית.
בהצלחה
רק ההגינות תנצח
oriel
הודעות: 2035
תודה!
