System: DM 7000-S
Image Info: CVS Compile on 15-04-2005 by Me
FP: 1.05
Emu: Latest Scam
Included: CIFS (connect to windows share)
Removed: Samba Server + Games
Keys: None
Major changes:
1. add ability to add manual services ( with manual pids ... vpid apid pcrpid tpid ) .. to use this feature open the manual scan.. enter transponder data here.. when you have transponder lock press the yellow button.. or select "manual pids"
2. fix for always 16:9
restore correct screensize after use of pictureviewer and 16:9 setting
3. fix for grouped satellite handling,
4. small fix for daylight saving & fix for showing real transponder time in timecorrection dialog
5. show remaining time in channellist (channelinfo) when the option is in expter setup selected
6. webif: add year to timers
7. webif: fix for & char in service description when recording thru epg
8. webif: tvbrowser timers now support years (you have to specify syear=%SY eyear=%EY in the capture plugin parameters
9. improved transponder scan
a) after sdt scan check for services they exist in the pat but not in the sdt
10. fix dvb subtitles ( add handling for 2 and 8bit subtitles, add default 4 bit clut )
now dvb-subtitles on cyfra+ are working correct
http://sat-industry.net/forums/attachme ... entid=4176
