יצאה גירסה חדשה 5 סופית
FlashWizard PRO 5.0 FINAL
What's new from 4.x?
* Support for images installed on NFS mount, you can install and start multiboot images from your Windows PC (or Linux PC)!!
A NFS server is required running on the PC side (I strongly suggest Microsoft Services For Unix 3.5 for Win XP PRO and Win 2K).
You can install images wherever you want, on USB and/or HDD and/or NFS.
* Added compatibility with images for DB 500 and DB 56xx
They are automatically recognized and installed, just drag&drop as ever.
Now FlashWizard is full compatible with DB 7000, DB 56xx and DB 500 images.
These can be installed either in flash and multiboot (on NFS server).
* Added Advanced SmartCopy
A powerful option that allows to full copy a list of file and/or folders from the active image to the new one being installed.
As for SmartSettings, it is full working also with images that have a compressed /var folder at install time.
WARNING_1: be careful with this option, use wildcards in filenames only if you actually know what you are doing.
WARNING_2: To avoid image malfunction, do not try to copy special dir/files (like /var/etc/init) between images developed by different Teams: every developer use these files to configure their images in a different way each one from the others.
If you're not an advanced user, limit the use of Advanced SmartCopy to plugins files and other useful addons ;-)
* New FlashWizard bootmenu (v1.4):
- automount NFS device at boot;
- display which devices are connected (USB-HDD-NFS);
- display where is installed the currently selected image (USB-HDD-NFS);
* If NFS server is down, FW will automatically boot-up from other available images, or from flash image.
* various improvements and fixes.
הקובץ נמחק יש גירסא חדשה 5.1
