4:2:2
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Watching MPEG 4:2:2 Transmissions
Download WinGrabE
Download and install VLC
* Start WingrabE.
* Select [Grab into a program stream file]
* NEXT
* Enter the DREAMBox IP ---- for example, I use 192.168.1.24
* Enter Video/Audio PID of the channel you want to stream. This can be either the channel you are currently tuned to, or another channel on the same transponder. (you can find these on the dreambox web interface. Make sure to select "Hex")
* NEXT
* Leave the [program stream file] name field empty.
* NEXT
* Leave [activate timer] empty
* NEXT
* The screen should have two boxes state and messages
* It may take 10 or so sec to load up.
* You need all 7 lines showing stuff ( not waiting for info)
* Open VideoLan Client
* Press Ctrl+N
* Select HTTP/FTP/MMS and type into the box: http://localhost:31337/start.mpg
* OK
Enjoy the beauty of 4:2:2 feeds
sm53
הודעות: 656
הצטרף: 05 ינואר 2004, 03:14
מיקום: tel-aviv
שליחה על ידי sm53 »
יש לינק ל WINGRAB ?
IT'S A LIVE
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
