The Swiss public broadcaster SRG SSR is preparing changes in the distribution of some of its programs on the Eutelsat Hot Bird satellite system at the 13 ° E position . In a month, the migration of some programs to another transponder will begin.
Day D is scheduled for March 9, 2021, when the SRG SSR will make changes in the distribution on transponder number 123 (freq. 10.971 GHz). Three SRG television program services - SRF Info, RSI LA 1 and RSI LA 2, as well as 26 radio stations (so far on TP 17) will be transferred to this transponder to the existing programs. The transmission on transponder 17 (freq. 11.526 GHz) will end at the end of June.
Viewers of SRG SDR and Kabelio have to retune the SRG SSR programs to the new parameters in the period between 12.3. and 26.5.2021. From March 12, the SRG SSR will insert rotating text information on the programs on TP 17 about the need to retune the programs. From May 26 to the end of June, a static screen with information about new parameters will be broadcast on TP 17 instead of television programs.
SRG SSR intends to inform about the need to retune its set top box or TV with a satellite tuner by a letter in which viewers will receive detailed information and help with retuning.
From July, the SRG SSR will use one transponder at 13 ° E. According to the operator, the technical quality will be maintained.
technical parameters - SRG SSR transponders:
• TP 123: Eutelsat Hot Bird 13B (13 ° E), freq. 10,971 GHz, pol. H, SR 29700, FEC 2/3, DVB-S2 / 8PSK, CA Viaccess + PanAccess
• TP 17: Eutelsat Hot Bird 13C (13 ° E), freq. 11,526 GHz, pol. H, SR 29700, FEC 2/3, DVB-S2 / 8PSK, CA Viaccess + PanAccess
