תדרים להוט
נעול
תדרים להוט
מכיוון שהרבה שולחים לי הודעות בנושא הנה התדרים שיש לי:
MATAV TEVEL ZAHAV
170 170 128
466 466 170
570 458 324
578 570 332
594 578 356
602 594 364
618 602 446
634 610 474
642 620 458
666 636 483
672 644 491
682 652 466
690 660 570
698 668 586
714 676 578
746 700 565
754 712 594
לירושלים דוגמא:
satellites.xml
קוד: בחירת הכל
	<sat name="Cable DVB-C" flags="0" position="900">
		<transponder frequency="1102000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1170000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1306000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1346000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1434000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1442000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1458000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1466000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1482000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1490000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1498000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1522000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1530000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1538000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1546000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1554000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1562000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1570000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1578000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1586000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1594000" symbol_rate="6510000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1602000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1602000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1610000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1610000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1618000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1626000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1626000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1634000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1634000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1642000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1650000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1650000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
		<transponder frequency="1000000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
	</sat>
cables.xml (למי שיש הפרדה בתוכנה ל-3 טיונרים נפרדים אפשר עדיין להשתמש רק בעליון)
קוד: בחירת הכל
	<cable name="DVB-C HOT" flags="1">
		<transponder frequency="187000000" symbol_rate="6875000" fec_inner="0" modulation="0"/>
		<transponder frequency="102000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="170000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="306000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="346000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="434000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="442000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="458000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="466000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="482000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="490000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="498000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="522000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="530000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="538000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="546000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="554000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="562000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="570000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="578000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="586000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="594000" symbol_rate="6510000" fec_inner="5" modulation="0"/>
		<transponder frequency="602000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="602000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="610000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="610000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="618000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="626000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="626000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="634000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="634000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="642000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="650000" symbol_rate="6890000" fec_inner="5" modulation="0"/>
		<transponder frequency="650000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
		<transponder frequency="000000" symbol_rate="6917000" fec_inner="5" modulation="0"/>
	</cable>
562 ערוץ 10
586 ערוץ 2
462 ערוץ 1
170 ערוץ 1 HD
נערך לאחרונה על ידי deepspace ב 15 אוקטובר 2014, 19:41, נערך פעם 1 בסך הכל.
הודעות: 2581
Re: תדרים להוט
תודה רבה.
אתה יודע אולי איך אני מכניס את זה לוויז'נט לאופרד?
Re: תדרים להוט
חפש לאיזה קובץ מכניסים את התדרים ותעתיק את הנתונים בהתאם לפורמט שהוא משתמש בו.
אם יש אפשרות לסריקה ידנית נסה ידנית מס' תדרים ותפעיל גם את NETWORK SCAN.
חפש תדרים לפי האזור התואם לך.
הודעות: 2584
הצטרף: 29 נובמבר 2004, 23:15
Re: תדרים להוט
שליחה על ידי צור .א »
אני חושב שהדיון בנושא הזה לא מקומו בפורום.יס\הוט אמורים להיות מחוץ לתחום.
הודעות: 2581
Re: תדרים להוט
צור .א כתב:אני חושב שהדיון בנושא הזה לא מקומו בפורום.יס\הוט אמורים להיות מחוץ לתחום.
זה נכון לגבי דברים לא חוקיים ואתה יודע למה אני מתכוון.
לסרוק תדר זה לא משהו שהוא לא חוקי.
הודעות: 2581
Re: תדרים להוט
מה התדרים של ערוץ 10 ו2?
אני תל אביבי ולא מצליח למצוא.
yousefk
הודעות: 291
הצטרף: 17 מרץ 2012, 18:19
Re: תדרים להוט
שליחה על ידי yousefk »
שלום
האם אפשר להכניס את התוכנה לממיר dreambox500hd ולא צריך כבל הוט כמו שאני מבין
yousefk
הודעות: 291
Re: תדרים להוט
שלום
האם יש תשובה
הודעות: 1068
הצטרף: 17 אוגוסט 2009, 13:03
Re: תדרים להוט
שליחה על ידי drsignal »
yosefk , אכן זה מיועד לממיר בעל טיונר כבלים ,
dm500hd הרגיל עם dvb-s2 לווינים רגיל לא מספיק .
יכול להיות שניתן להתקין ב dm500hd טיונר מסוג triple tuner , בהנחה שהטיונר plug&play וזהה ל dm800se
אז אולי ניתן להרכיב כזה טיונר במקום הטיונר המקורי של
dm500hd
בנוסף לעניין הטיונר אתה צריך תשתית לכבלים ...
yousefk
הודעות: 291
Re: תדרים להוט
הודעות: 2581
Re: תדרים להוט
שלום,
קצת קשה לי להבין את הטבלה. יש לי את כל התדרים אבל אשמח בבקשה לתדרים של הhd כגון הוט8 ערוצי הסרטים וספוט 2 HD.
הודעות: 2581
Re: תדרים להוט
נעול
