Black Hole Vu+ SOLO - UNO - DUO 1.7.6
מדור זה מיועד לקבצים ולינקים לממירי VU+
yoramile1
הודעות: 6122
הצטרף: 02 ינואר 2004, 20:47
Has thanked: 6 פעמים
שליחה על ידי yoramile1 »
New Green Panel Setup
- Customize the plugin list. You can now assign a progressive position number to plugins.
New drivers Vu+ drivers 20120628
- Improve vtuner performance
- Support 2 zapping mode(hold, mute)
- Optimize memory usage in demux driver
- Change dual tuner locking mode
- Support streaming interface(Remote Channel Stream Converter)
- Support H/W Graphic2D acceleration for HBBTV
- Fix incorrect VFD display(duo, uno)
New Skin Army TranSpaRency HD
- Awesome skin with low graphic impact. Another little masterpiece of our master Army.
New Plugin AddStreamUrl
New Plugin ZappingModeSelection
Add support http ts stream.(client)
Disable hdmicec plugin' for default
Load Bouquets' support for non dvb services.
adjust kernel config for size reduction
WirelessLanSetup : fix bug (AP's protocol info is None)
StreamTv plugin: fix bug.
WirelessLanSetup : If wireless lan module is activated, do checkIfaceMode
