Black Hole SOLO - UNO - DUO 1.7.5 "Multiple"
מדור זה מיועד לקבצים ולינקים לממירי VU+
yoramile1
הודעות: 6125
הצטרף: 02 ינואר 2004, 20:47
Has thanked: 6 פעמים
שליחה על ידי yoramile1 »
Black Hole 1.7.5 "Multiple"
The "codename" of Black Hole 1.7.5 is Multiple because it is
Multi Boot
Multi Universes
Multi Partitioning usb sticks
Multi UPnP servers (Mediatomb and Minidlna)
What's New:
Multi Partitioning
Parallel Universes Setup with the option to protect access with a pin code
Enigma2 dvbapp updated to 31 May 2012
Army default Skin updated
Added a second UPnP server (Minidlna) for maximum compatibility with all current tv's
Note on Multiple Partitioning:
The "Usb Format Wizard" of Black Hole 1.7.5 will allow you to partition and format your
usb sticks from 1 to 4 different partitions.
You can for example create 3 partitions in your usb stick and then mount them in 3 different mountpoints in device manager (i.e usb, universes, cf)
Note on Universes setup:
By clicking ok you will now access the Universe Configuration menu (Black Hole home doesn't need a config)
You will have 3 options:
Universe access protected
Universe access pin
Force reboot in Black hole.
Setting the first option to Yes, will mean that the Universe will be protected with a pin
If you do not set a pin the default pin will be 0000
Setting force reboot in Black Hole means the image will not boot into this Universe (useful for a pin protected universe, to be sure that nobody can access it, if you forgot to switch to another dimension before you poweroff).
Note: the Universes pin and config are reset by a big bang
Note on Multiple UPnP servers.
Black Hole 1.7.5 include 2 different Dlna Servers:
Mediatomb
Minidlna
- Mediatomb allows you to stream between two different boxes and take advantage of the BH Tuner/Server feature, but it is not compatible with many devices and the project is no longer updated.
- Minidlna is more upto date and compatible with many devices and most modern tv's. Use it if you want to connect from your tv or other devices to your box to share your media contents.
"Samsung QE55Q80T 4K QLED 55
Zgemma h7s
Vu+ Ultimo 4K
Vu+ Uno HD
TeVii S472 DVB-S2 PCIe
