pgi v1.3 komunga
mbd
הודעות: 657
הצטרף: 08 דצמבר 2009, 14:48
שליחה על ידי mbd »
| PGI v1.3, |
THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. UNDER NO CIRCUMSTANCES WILL THE PGI SOFTWARE AUTHORS BE LIABLE FOR ANY INDIRECT, INCIDENTAL, CONSEQUENTIAL, SPECIAL OR EXEMPLARY DAMAGES, DATA LOSS OR HARDWARE MALFUNCTION, ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE UNDER NEGLIGENCE OR EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. BY INSTALLING AND USING THE SOFTWARE YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
Change List for PGI 1.3
- New: Recording 2 channels from the same transponder works now
- New: Current programme remaining/elapsed time can be displayed in minutes or as perecent in the channel list (new option in the PGI Settings menu)
- New: Programme description is shown in the channel list (1 column + 3 EPG events mode), this is optional and can be turned on or off via the PGI Settings menu
- New: Added DiSeqC 1.0/1.1 settings for motorised dishes used in so-called "cascaded" configurations: Motor + DiSeqC
- New: Last watched recording is remembered in the recordings list
- New: Added/removed and changed some HDD related options, please read HDD_en.txt (even if you have done so before)
* HDD_MEDIA, NFS_REC and NFS_REC_PROTO parameters in pgi.conf have been merged into a single parameter called MEDIA_DEVICE
* MEDIA_DEVICE can now be specified using partition's UUID as well as classic /dev/sdxX syntax
* Included mkdosfs utilities to format disk/USB flash partitions as FAT32
* All swap partitions on all available devices are now mounted automatically, i.e. swap does not need to be 1st partition on your disk
* Swap can be an ordinary file now (see new parameter called SWAP_FILE in HDD_en.txt)
- New: Added/removed and changed some USB 3G/UMTS modem related options (see NETWORK_en.txt)
* Removed USB_MODEM option from pgi.conf since USB_modeswitch now operates automatically
* PPPD_PEER parameter has been renamed to PPP; ATTENTION: PPP must be set to a valid value for USB_modeswitch to work (at boot)!
* Added picocom utility for testing and setting up your USB modems (see NETWORK_en.txt for usage example)
* Improved 3G modem config templates in /var/etc/ppp including "on-demand" connections (dial up only when required, autodisconnect when idle)
- Fix: Improvements for non-persistent epg.dat handling (when there is no USB/SATA storage used), less problems with channel list "freezing", etc.
- Fix: EPG database structure changes: stopping recordings should be faster now (all existing EPG data will need to be refreshed)
- Fix: Instant recording popup setting for shutdown/standby power option is working correctly now
- Fix: Recording names are displayed correctly now
- Fix: Editing recording name (instead of recorded channel name) is possible now
- Fix: WebTV was not working correctly when the second tuner was used
- Fix: DVB subtitles fixes and improvements (especially for Nordic channels)
- Fix: Timeline in EPG Grid moves properly now
- Update: OpenSSL, USB_modeswitch, Busybox, MC, Freetype, SQLite, Dropbear, e2fsprogs and Transponder DB updates
- Removed: Weather Info.
Images for all boxes can be downloaded
Here: http://goo.gl/fmROm
As mentioned before, the addon 008 has a failure.
Here is now an improved new PGI addon 009 for PGI 1.3
The problems with card initialisation should be fixed.
New oscam version 1.20 unstable v6157 included.
Da das Addon 008 einen Fehler hat, hat mir eine freundliche Seele die uns gewogen ist, eine bereinigte Version zugeflüstert....
Hier das PGI Addon 009 mit oscam 1.20 unstable v6157
http://www.megaupload.com/?d=6I96OH40
כל מי שהיתקין ADDON V008 שיתקין את ADDON V009 במקום.
eli123
הודעות: 147
הצטרף: 14 אוגוסט 2007, 21:46
שליחה על ידי eli123 »
מה זה ADDON V008 ואיך מתקנים
mbd
הודעות: 657
שליחה על ידי mbd »
כמו שכתבתי מתקינים את ADDON V009
זה הקובץ השני [61960H40 ]
זה הקובץ שמכיל את ה-EMU [כל הקמים כדי לפתוח ערוצים]
מתקינים דרך ה-WEBIF
2pac4u
הודעות: 633
הצטרף: 11 יוני 2006, 13:01
שליחה על ידי 2pac4u »
חודשים לא נכנסתי למדור הזה.
תודה על החדשות,בשבת בדיוק קרס לי האימגי האחרון של SIFTEAM,דווקה עבד חלק כמעט חודשיים.התקנתי את ה-PGI,עד עכשיו ניראה מבטיח,מה שכן הפונטים בתירגום לעברית ניראה לי קטן ???
ושמתי לב שהם הראשונים שקימפלו מחדש את האמולטור
Mgcamd v1.38 by mixvt, patched by D2MAC on Oct 23 2011
mbd
הודעות: 657
שליחה על ידי mbd »
האימג" עובד מעולה לא קרס לי אף פעם . אין פריזים .
עבורי MGCAMD 1.33 עובד הכי טוב .כמובן צריך להוסיף
אותו ידני כי הוא לא בררת מחדל .
בקשר לפונטים יש כמה שפות שהם מופיעים קצת קטנים וזה
ישתנה בגירסה הבאה.
Jaaz
הודעות: 174
הצטרף: 23 יוני 2009, 09:47
שליחה על ידי Jaaz »
עם PGI 1.3 סבלתי מהמון תקיעות וקריסות.
אמנם בעל יכולת פיענוח EPG טובה בהרבה מאשר image מקורי מבוסס Sif, אבל לא יציב בעליל.
לאחר חודש עם PGI אני שוב עם Sif שמח ומאושר.
7W-4W-4.8E-13E-16E-19.2E
1.2 meter dish
mbd
הודעות: 657
שליחה על ידי mbd »
העיקר שאתה שמח ומאושר.
