למכירה Satlink WS-6912
MikeSG
- הודעות: 98
- הצטרף: 17 דצמבר 2008, 17:20
שלום לכולם,
אני מוכר את ספקטרום SatLink WS-6912
קניתי כאן
http://www.transplanet.fr/boutique/info ... 8664&fam=4
פירוט
DVB-S2 DIGITAL SATELLITE METER
SATELLITE METER & REAL TIME SPECTRUM ANALYZER
Main Function:
SYMBOL RATE 8PSK AND QPSK
3.5 Inch High definition TFT LCD Screen which Can show live Channels
NEC Solution
Shows both S/N and C/N
Shows strength and quality readings
Sound and Light Alarm When Lock Signal
Shows channel picture
Show numerical reading and bar reading
Digital Meter for Signal Strength(in numerical & #118alue and picture)
Easy Satellite Manager ( EDIT, delete and SCAN)
Edit TP, Frequency, LNB switch, Symbol Rate etc.
Completely programmable by the user
Input Frequency 950-2150MHz
Input Level -65-25dBm
Input Impedance 75(ohm)
Auto Calculate Angle of AZ ,EL
Upgrade S/W by PC
Easy to carry, size only 9.5cm X 15.5cm X 4.5cm
DisEqC Control
22KHz Control
Fast Charge LI-ION Battery(1950mAh), Can Last 4 Hours
Indicator Lights for 13/18 volts
Indicator lights for 22 KHz
USB port for software upgrades
USB software upgrade cable included
Neck strap includes
Carrying case included
12VDC power charger included
For the first time in a economical digital meter, you are now able to view the actual channel on the screen of the meter. Now you can quickly and accurately align the satellite AND you can instantly check the stability of the channel right on the screen of the meter. Transponders, Frequency, Symbol Rate, Polarity, and other settings can be modified by the user. There is never a need to send your meter in for a upgrade.
Meter never needs to be returned for re-calibration due to the unique calibration system built in to the meter. Each time the meter boots up it automatically calibrates for optimum performance so you can align each install with confidence.
Technical Parameter:
System capabilities
Fully DVB compliant
Yes
LNB/Tuner input
Connector
F type,male
Frequency range
950MHz-2150MHz
Signal lever
-65dBm~-25dBm
LNB supply
13/18V,max400mA
LNB switch control
22KHz
DiSEqC
Ver 1.0 /1.1/1.2
Demodulator
Front end
QPSK and 8PSK
Symbol rate
2Mbps~45Mbps
SCPC and MCPC Capable
Yes
Spectral inversion
Auto conversion
System resource
Processor
32bit processor (200MHz)
SDRAM
64Mbyte
FLASH
16Mbyte
EEPROM
8Kbyte
Video decoder
MPEG 2
Main Proflie@Main Level
Data Rate
up to 15M bits/s
Resolution
720*576,720*480
Video format
PAL/NTSC/SECAM
MPEG Audio
MPEG 1 layer 1&2
Type
Mono
Sampling rates
32,44.1 and 48KHz
Serial data interface
Connector
USB type
Power supply
Li-oN Battery
1950 mA
Supply voltage
12.6Volt
charger
90-240V
Panel connectors
Digital tuner input
F type, male
Physical Specification
Size
9.5x15.5x4.5 (cm)
Weight(Net)
0.5 Kg
מחיר:
1750 ש''ח
אני באזור השרון
http://imageshack.us/photo/my-images/851/001grz.jpg/
http://imageshack.us/photo/my-images/600/002aft.jpg/
http://imageshack.us/photo/my-images/707/003xji.jpg/
http://imageshack.us/photo/my-images/37/004auj.jpg/
מי שקודם זוכה
יום טוב לכם
קניתי כאן
פירוט
Main Function:
NEC Solution
Upgrade S/W by PC
DisEqC Control
22KHz Control
Neck strap includes
System capabilities
Fully DVB compliant
Yes
LNB/Tuner input
Connector
F type,male
Frequency range
950MHz-2150MHz
Signal lever
-65dBm~-25dBm
LNB supply
13/18V,max400mA
LNB switch control
22KHz
DiSEqC
Ver 1.0 /1.1/1.2
Demodulator
Front end
QPSK and 8PSK
Symbol rate
2Mbps~45Mbps
Yes
Spectral inversion
Auto conversion
System resource
Processor
SDRAM
64Mbyte
FLASH
16Mbyte
EEPROM
8Kbyte
Video decoder
MPEG 2
Data Rate
up to 15M bits/s
Resolution
720*576,720*480
Video format
PAL/NTSC/SECAM
MPEG Audio
MPEG 1 layer 1&2
Type
Mono
Sampling rates
32,44.1 and 48KHz
Connector
USB type
Power supply
Li-oN Battery
1950 mA
Supply voltage
12.6Volt
charger
90-240V
Panel connectors
Digital tuner input
F type, male
Size
9.5x15.5x4.5 (cm)
Weight(Net)
0.5 Kg
מחיר:
1750 ש''ח
אני באזור השרון
מי שקודם זוכה
יום טוב לכם
Dreambox 500S
2.0.11
13.0E - 19.2E - 7W
1.80 מ'
2.0.11
13.0E - 19.2E - 7W
1.80 מ'
- NeymanPearson
- הודעות: 60
- הצטרף: 28 יולי 2011, 16:41
MikeSG
- הודעות: 98
- NeymanPearson
- הודעות: 60
MikeSG
- הודעות: 98
- NeymanPearson
- הודעות: 60
MikeSG
- הודעות: 98
syaros
- הודעות: 902
- מיקום: כרמיאל-חיפה-יקנעם
MikeSG
- הודעות: 98
syaros
- הודעות: 902
syaros
- הודעות: 902
MikeSG
- הודעות: 98
MikeSG
- הודעות: 98
MikeSG
- הודעות: 98
MikeSG
- הודעות: 98
MikeSG
- הודעות: 98
MikeSG
- הודעות: 98
