כמו שידוע האימג' באה מוכן עם כל האמולטורים.
http://www.bmteam.eu/download/?&&path=i ... ken-13744/
Change List Since Last Release-----------------------
- fixed: blindscan and fastscan improved
- fixed: youtube buffering improved
- fixed: display/refresh EPGLIST when using RED/GREEN button (jump of more than one channel without releasing the key)
- changed: more audio/video files and variants supported in mediaplayer
- changed: three-step function of WWW, RED, GREEN, YELLOW and BLUE buttons reduced to two-step function
short press is 1.(first) action
long press is 2.(second) action
BMT defaults as below:
1. www (www.sh) - not used (can be defined by user)
2. www (www2.sh) - not used (can be defined by user)
1. red (red.sh) - aspector plugin
2. red (red2.sh) - not used (can be defined by user)
1. green (green.sh) - emuman plugin
2. green (green2.sh) - not used (can be defined by user)
1. yellow (yellow.sh) - bitrate plugin
2. yellow (yellow2.sh) - hddtemp plugin
1. blue - Instant Recording List
2. blue - Record Status (scheduled recording list)
- changed: bitrate plugin improved
- changed: hddtemp plugin improved
- changed: two-step function of OK button moved to EPG button
short press - epg grid
long press - epg list
- changed: aspector new features
- changed: busybox modifications
- changed: kernel options optimised
- added: picons handling for channels at infobar
- added: private_aspect_info file to automatically change the aspect ratio for the selected channels (in accordance with the sender information: 16:9 or 4:3) - works only with 16:9 setting in menu
- added: in EPGLIST < and > button works as RED and GREEN buttons
- added: NTFS partitions are wittable now
...and many many more, that will be officially listed in Scylla
