Cuberevo-digital release r13736: (15/April/2010)
1. Change - ftp & telnet id : root, password : pw
2. Change - Web interface id : admin, password : pw
3. Change - First Local Time Setting - Germany
4. Chnage - TP information for HOTBIRD : 11681, 27500, Horizontal, DVB-S2, 3/4, 8PSK
12692, 27500, Horizontal, DVB-S2, 3/4, 8PSK
5. Fix - youtube doesn't work.
6. Fix - Post Descrambling bug.
7. Fix - Several bug.
Caution
1. Back up your data of HDD except the version of r12947 software in your box
At first, you have to back up recorded file or photo, mp3 data from STB
before downloading this image if you need. This image is supported to something
different file format or data format compare with previous software image.
2. Format HDD except the version of r12947 software in your box
You should be format HDD after downloading completed this new image,
otherwise, it will be possible to malfunction about PVR, timeshift, mp3,photo album and so on
Note.
1. Prohibited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
__________________
IPBox 9000HD - 91HDhttp://cuberevo-digital.com/Cuberevo Series 1.0.(r13736) version
Image version : r13736
DB version : r13489
Caution)
1. You had better backup the channel list using PC Editor before downloading the new images.
2. If your STB db version is an older version, you should download the image with usb_db.img like usb_kernel_root_db.img usb_nobbot.img.
If your STB db version is the same version, you can download the image without db.img like usb_kernel_root.img.
3. If AC power is unstable or disconnected while image downloading, pictures may not appear on the screen properly. In that case, you should make USB download mode once more and perform downloading the image again.
4. Please read the README file carefully before you start downloading.
Cuberevo : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-Mini : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-3000HD : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-250HD : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-200HD : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-2000HD : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-7000HD : ftp://dev.cuberevo-digital.com/pub/cube ... noboot.zip
Cuberevo-100HD : http://dev.cuberevo-digital.com/~wunseo ... noboot.zip
if you want multiboot function, download attached multiboot-XXXX.img.
Then press number button which you want on RCU when start up from shutdown.
Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
u-boot is attached as below.
To get patch files related to GPL license, please click HERE
uboot.zip (966.44 KB) multiboot_config.zip (6.92 KB) README_r13736.txt (6.28 KB)
