עזרה בדרים לאיפון
hedva sat
הודעות: 307
הצטרף: 18 אוקטובר 2004, 10:34
שליחה על ידי hedva sat »
אני צריך עזרה אייך להעביר את הדרים
לאיפון יש את ה air video
אבל צריך לשים כמה דברים בfile
ואני לא יודע אייך
עזרה בבקשה
naveh
הודעות: 283
הצטרף: 27 אוקטובר 2005, 17:57
שליחה על ידי naveh »
Air Video can stream videos to your iPhone or iPod Touch. Besides the app you must run the free of charge server for Windows or Mac. That is very nice for playing your recorded videos. But I'm sure you will like my Air Video server mod even more. I've modified latest Air Video server so that it enables you to select and play live video streams from your set top boxes (e.g. Dreambox or Dbox). A TV channel can be selected from a channel list (a list with channel logo thumbnails). Air Video server then sends a zap (channel change) command to the set top box and the stream can be played on the iPhone using live conversion. This works perfect and you can view your favorite TV channels live and in good quality wherever I am via wifi and 3G. Years ago I developed the PMP VLC player for the Sony PSP which is quite similar to Air Video and when I found Air Video I knew it is the killer app for the iPhone and iPod Touch
Installation
First install Air Video on your iPhone or iPod Touch, then install the latest server on your Windows PC or on your Mac
To install my mod perform following steps:
- download and unpack my Air Video modpack from the attachment (10MB)
- replace the ffmpeg program by the one in my modpack. On your PC replace ffmpeg.exe in the directory where you installed the Air Video server (e.g. C:\Program Files\AirVideoServer).
- copy channels.ini to your PC in the directory where you installed the Air Video server (e.g. C:\Program Files\AirVideoServer)
- copy the LiveTV directory to your PC and add it to the shared folders in Air Video server. This directory contains the channel logo thumbnails (these are in fact 1 second duration mpeg4 files). Included are about 50 German Astra 19.2 channels
- edit channels.ini and replace the IP address 192.168.1.96 by the IP of your Dreambox or Dbox2
- (for client versions before v2.1.3): add a preset "LiveTV" in the Air Video client on the iPhone: width 480, height 272, quality e.g 70% (the quality heavily determines the average bitrate and for Internet access (3G or wifi) it should not be more than your upload speed! Via 3G I have good results when quality is set to 50%. Experiment with it and look up in the server log what actual bitrates you achieve
- (for client v2.1.3 and later): click conversion settings and then click Global Conversion Settings. The live TV stream quality depends only on the Max. Resolution settings and Quality for Offline Conversion slider. I recommend to keep the Max. Resolution settings on Automatic and only use the Quality for Offline Conversion slider to set stream quality.
- if you installed everything correctly and the server is running you can start Air Video on your iPhone, add the server and open the LiveTV - German TV folder. Select a channel from the thumnail list and press "Play with Live Conversion" and then press play from "The Beginning". If after 6-7 seconds you see a warning message press "Continue". In total after pressing "Play with Live Conversion" it takes about 25 sec before you see the picture.
- streaming sd channels works perfect for most of the sd (standard definition) channels. Some channels do not correctly multiplex the elementary streams into a ts stream and won't play, CNBC Europe is an example. Unfortunately the Ffmpeg encoder can not correctly demux hd channels and therefore hd channels only play a few seconds.
- if you stream from a Dbox2 you must first switch off "Playback" and "Sectionsd". You can do that in the Control menu via the dbox yWeb interface.
- you can get a near perfect picture quality if you select the highest quality preset in Conversion Settings.
- IMPORTANT: to ensure uninterrupted streaming make sure your set top box and the PC running Air Video Server are connected to your wlan router by ethernet cable. If you connect them by wifi or powerlink there is a high probability the stream stops playing after a few seconds.
Customisation
On the server the file called channels.ini must be added with 3 lines for each channel: thumbnail movie filename, zap url, stream url. The zap url is sent to the set top box once the user starts live playback and the stream url is the stream which is being transcoded by Air Video server.
VU+ UNO
Astra 23.5°E - Amos 4.0°W - Hotbird 13.0°E - Thor 1.0°W - Astra 4.8°E
Eutelsat 16.0°E - Astra 19.2°E - Eurobird9.0°E - Eutelsat 7.0°E - Hellas 39.0°E
hedva sat
הודעות: 307
תודה על העזרה
ניראה לי מאוד מסובך
מכיר את הכתבה אני צריך עזרה בטלפון יש הרבה דברים שאני לא מבין בקיצור לא איש טכני
נראה לי שסלינגבוקס קל יותר
eli.racheli
הודעות: 1681
הצטרף: 09 מרץ 2008, 16:06
שליחה על ידי eli.racheli »
אכן סלינגבוקס נראה פשוט יותר אך בשביל זה צריך לשלם 1000 ש"ח.
יש את המדריך הזה :
http://www.i-have-a-dreambox.com/wbb2/t ... =air+video
שמסביר צעד אחר צעד מה צריך לעשות , יש תוכנה שנקראת Bouquet Editor Suite שמכינה את כל הקבצים למחשב באופן אוטו' ואז לא צריך לערות את הקובץ.
האימפריה בצהוב !
naveh
הודעות: 283
זה די פשוט הנה הקבצים הנחוצים, לפי ההסבר.
http://www.megaupload.com/?d=YAUJQJXY
http://www.megaupload.com/?d=MS1G03V2
http://www.megaupload.com/?d=FZDKOR4B
בהצלחה
VU+ UNO
