גירסת חברה 108.2
כבר יצא היא בבדיקה
8)
DMM releases 1.08.2
The original readme.
Fixed reboot bug ...
USB fixed
Deadlock in squashfs2.0 fixed (Used new kernel patch from squashfs side)
"Unknown Partition Table" when mounting USB sticks fixed
Kernel Version is now 2.6.9-rc1
Illegal Instruction when loading binary's that were compiled with Coprocessor was repaired (Kernel Coprocessor EMU activated)
CVBS is now standard after loading the driver module as long as nothing else was selected
Coldstart problem on Horizontal Channels fixed (e.g. RTL)
/cgi-bin/getServices improved (Provider/Orbital Position.. for DreamTV)
WebIF updated (repear timers can now be selected with Webif, fixed small problems)
New Toptext Tuxtxt
EPG Style setting now applies to outside the channellist as well (dobbelpress Red to open selector)
Problems when entering CI Menu fixed ... when CI was just active
Expert Option 'Don't open Serial port' didn't work
Delay for MessageBox "please wait until the timer has started the recording (max 10 seconds)" set to 10 .. not 10000
Timer recording didn't work when when an event occured and you previously watched a film all the way to the end, then the previous message appeared.
Fixed German MMI ... spelling errors
Bug fixed in Channellist (when in Datamode you would select files, including files known by enigma, and then used bouquet +/-, the enigma files were handled as data)
Disabled Timer Logfile
plugin.cfg option required built in (e.g. network or dsl)
When a CI was inserted, you could hardly get to the Shutdown menu.
When a repeat timer was in the timerlist and a new event was entered, it was repeatedly asking if the box should be shutdown or set to standby.
After a timerrecording in Standby, if you woke up the box, the box was set to standy anyway after the event.
Fixed Satellite Scan (on Astra you could only find 370 channels)
'Only FTA' scan improved ... and resulting lost channels fixed
