http://www.dream-multimedia-tv.de/dm700 ... l108_1.img
עדכון תוכנה
rel108_1
Bow quick: ---------.
- Time correction (can one well on TURKSAT42°E test.. there are the Transponderzeiten totally broken (all other as an UTC what there in the TDT sent becomes)
- HP Player (VOB/MPEG1/MPEG2/VDR) some file only shortly were alluded or remained sometime simply stand
- If a DVB include in ran the Standby and roused stood has was is stand remained one the box.. this however previously on an incorrect transmitter.. the reception there then bzw
- In the hinzufügene of a new Events in the Timer was asked whether one drive down the box and/or wants (sometimes) go in Standby
- If one had on a transmitter gezappt, that sent no EPG, the EPG was held stood has at the time not up-to-date.. as long as one on the transmitter.
- Russian EPG
- The DVB Library is now robuster against broken Descriptoren/Sections (u. a. quick für show Time on Nilesat 7.0°W)
- The EPG is now consistent.. no Error messages embarrassing more
- In a repeated Timer the repeated hooks save drcken remove then.. then fall
- Sporadic Abstürze "Attempt to close non execing widened" removed
- the box partially reacts to remote controls of other gerate
- Windows check are editions in the hard disk now somewhat more readably (at least EXT3)
WebIF: ------.
- Bow quick Timer do not set occurred if in the description high comma or Anführungszeichen functioned
- Bow quick Standby Wakeup did not function
- Bow quick in the zappen on "Sunshine live" (and other transmitters) crashte enigma
- Colored genre gradation in the Multiepg
- Support für programming of Timern über "tvbrowser" implements
- /cgi-bin/currentTransponderServices geändert.. the services name becomes there now with angefügt (für DreamTV)
- /Cgi-bin/showServices hinzugefügt.. for indicating all services - in Bouquets - in provider' n - in the all
services cunning - a certain satellite - the recorded movies - etc.
Other: --------.
- Network accelerates and Overruns gefixt (nfs now should be also again better)
- Less storage consumption in that play back of HP files (VOB/MPEG1/MPEG2/VDR)
- Änderungen at the MP3 internet streaming.. before played back becomes, become now first of all nen couple of data gecached.
- More priorität für the EPGCache.. through it no Lücken should emerge would be sends occurs more in the EPG.. it then the transmitter simply only Müll what also schonmal.
- Support für more sign conversion tables (8859-X -> UTF8) incorporated.
- FP (AVR) Update on 1.01 für all boxes
- Automatic Lautstärkeregelung first of all expanded ate.. extremely much Performance in the Kernel and not
yet is matureed
- Grouping of transmitters in the ABSAT and POLSAT provider improves
- In "all services" and each providers one can rename be contained is now transmitter this Änderungen then also into each Bouquet and each provider übernommen in which of that of the transmitter. The entire is send helpful, für transmitter the names incorrect simply nen über Sat. In order to restore the original name, simply again rename remove... at the same time then however all signs and abspeichern. Then the transmitter stands as long as as an "unnamed service" in the list until one either on the services themselves zappt, or however on another service on the same Transponder.
- In "all services" and each providers one can remove is now transmitter.. this however Exclusively in addition there in order to remove from old or incorrect services the list. One removes a service that yet up-to-date/okay is (in the SDT stands), this becomes eingefügt again automatic in the nächsten Zappen on a service the same Transponders.
- Kernel update on Vanilla Kernel 2.6.8.1 (of www.kernel.org)
- Pacman gefixt and again into the image incorporated
- Usbhid driver is contained now in the image. (u. a. für USB Keyboards)
- EXT3 tools geupdatet on e2fsprogs-1.35
- Busybox geupdatet on RC2 (cvs stood 20040816)
עידכון rel108_1
New Features:
* Kernel upgrade to 2.6.5
* Dreamkeyboard-Support activated (Keyboardsetup for changing Layout available)
* current Web-Inteface from cvs
* added dhcp-support
* added passwordprotection to Web-Interface (can be disabled in expert setup)
* auto retune when signal is lost for a short time
* left/right mono works now too, when channels sends only stereo (former it only worked when 2 mono-channles were sent)
* Endtime and what should happen when timer is over (nothing/standby/shutdown) can now be changed during running timer-events
* At the End of an timer-event the box controls if there starts another timer-event during the next 10 Minutes,
if not, you will be asked if the box should go into standby/deep standby (30 sec. timeout)
* on deleting an recorded movie, the name of the movie will now be showed in the "Are you sure"-Window
* debug-output on serial port can be disabled in expert-setup (needs to be enabled for installing settings over serial port)
this is optional because the serial port can't be used otherwise when enigma opens it.
* enigma now sets up linux-time
* removed option to format with ReiserFS. reiserfsck still available.
* increased maximum number of LNBs to 32
* fast-zapping option in expert-setup, when enabled, everthing is as it has always been, when disabled, zapping is a little slower but
there are no more of that short sync-freezes
* DVB-Subtitles work now (e.g. 15°W Extreme Sports - crypted) - can be enabled in Audio-Menu (yellow Button)
* Added factory-reset (actually the same as a flash-erase)
* Added automatic volumeadjustment (enable in Audio-Menu with blue Button an choose Volume with Vol+/-).
Works best when you turn the Volume to the max. before using it.
* Added Help in Textinputfields.
* no more need grabber.o to make a screenshot (but no deinterlacing).
* added sleep/wakeup-scripts (/var/etc/enigma_enter_standby.sh and enigma_leave_standby.sh)
* max filename lenght is now 100 Characters.
* for dvr timers enigma never more do wakeup from standby
Bugfixes (most important only)
* fixed Memory-Leaks
* Last chosen Mode (File/Radio/TV) will be restored after restart
* Fixed various Bugs according to recordings
* New found services will be added to the correct Provider (SDT-Scan)
* Automatic-Symbolrate-Correction
* MPEG-Decoder now uses full Chroma-B-Framebuffer
* fixed Satfind
* some fixes in Transponderscan (e.g. twice scanned services)
* fixed PS-Player
* fixed keychatter
* fixed timezones
* lower memory comsumption
* repeated timers can now be canceled when recording hasn't started
* testpictures are now available again (Video-Setup - Test). You can switch between the pictures with the numbers.
* some CI-fixes
* improved EPG-Cache (caches more Data now)
* fixed freezes on format-changes (4:3->16:9 and t.o.w.a.)
* freezes on changing from regional program to normal program
* small fixes on parental-lock
* polish EPG now works correctly
* and many more fixes
* fixed Satfind
* fixed PS-Player
* fixed keychatter
* fixed timezones
* some CI-fixes
