SWF Vizyon 80../ipbpx90..E2_V2.0 for flash and usb
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
Today is new SWF Vizyon out. Transfered from Minicats forum. Thanks to SwennaDeluxe.
Interested image based on Tideglo rev.0.7.5 with some interested solution about pasnel-cam menagement, and predefined cams, and much more...Easy to install. Whats new?
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
SWF MOD :
- eigenes SWF-Panel
- Bootlogo geändert
- cardreader support
- swf-panel installierbar (script-executer)
- Enigma2.mo angepasst auf vizyon
- Telnet-login überarbeitet (root / vizyon)
- Videotext auf Wunsch nun Vollbild
- png im Webinterface getauscht (webtv)
- Web-Interface Style geändert
- incubus 0.96, mbox , camd3 mgcamd sind bereits enthalten ( Blue Panel )
Danke an mcron und alle Tester
-User = root
-Passw.= vizyon
Password can easy change in panel. Very easy to menage cams, rešplace only a couple of files with your own.
I not so much tested, only about a half of hour, but look at stable.
Cheers
acer2
SWF-Vizyon-8x0/0-E2_V2.0
-User = root
-Passw.= vizyon
not really, here are the links:
IP-Box 91HD ( 250HD )
USB
http://np-ulc.net//index.php?action=dow ... 50HD%20%29&
Flash
IP-Box 900HD ( Mini )
USB
http://np-ulc.net//index.php?action=dow ... Mini%20%29&
Flash
http://np-ulc.net//index.php?action=d ... 900HD%20%28%20Mini%20%29&
IP-Box 910HD ( Mini2, 3000HD )
USB
http://np-ulc.net//index.php?action=dow ... 00HD%20%29&
Flash
IP-Box 9000HD
USB
http://np-ulc.net//index.php?action=dow ... x%209000HD&
Flash
found the links at RSP Forum by PETER36. so credits to them.
Thanks to SWF for this image, will try it soon!
התקנתי על 250HD וזה מפתיע מאד
אימג יפה ועובד מצוין עד כה.
