Enigma 2 Nightly Build: 0.7.5 version
- הודעות: 2791
Quote: Originally Posted by Readme release 0.7.5
- added possibility to search channels by channel name's first letter,just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connectother devices to the box and see automatically the TV signal whencuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in theA/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels(like Universal Channel with Romanian subtitles, TotalTV and so on:report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on somechannels (like Mega, Star, ANT1 in package Netmed: report if now itworks good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
Enjoy it! Tideglo [/t][/t] Flash and USB versions here
http://enigma2.sifteam.eu/index.php?dir ... d%200.7.5/
- added nc
- marcelos
- הודעות: 1028
- הצטרף: 11 פברואר 2005, 09:54
- מיקום: קרוב, בסביבה
- dudutr
- הודעות: 1440
- הצטרף: 25 ספטמבר 2006, 18:09
mikiha
- הודעות: 151
- הצטרף: 23 אוגוסט 2009, 01:07
- הודעות: 2791
עדיף להמתקין לגרסאות היותר מפותחות של PKT ואחרות, או עדכון של SIFTEAM,
מסתבר שגרסת EMUMANAGER לא עובדת על גרסת 7.5, יש שגיעה בסקריפט של הפייתון
אני מאמין עוד יום יומיים, בגלל החג זה יתעקב אולי, אבל PKT יוציאו גם EMU לזה
- dudutr
- הודעות: 1440
