על אחריות המשתמש! [לא הוספתי את הקובץ כי לא יכולתי לבדוק.. טוב, נצטרך לחכות ל"אישור"]
From darkman
Matrix Reloded Is Working Seca2 Sky Italia -d+ Emu +coax
WORKING 100% MATRIX MAGIG AND A LOT OF RECEIVERS
Multi Emulator for sidsa based modules and receivers (Xtreme, @sat, magic module, matrix etc.)
This program emulates conax and seca2, it's a standalone emulation and does not support any type of c*rd.
It's mostly for people who have an emulation firmware where conax/seca2 is not included, for example
in my case, the @sat emu-firmware running in an xtreme str.
Installation:
- Remove any c*rd from the module/receiver.
- Clear the flash.
- Write MultiEmu.bin to the flash, starting from address 0.
- Restart the receiver or plugin the module.
Known issues:
- When switching to a conax channel, it takes about 5 seconds before the first picture starts,
this is due to the decryption algorithm, I have a few ideas, so this might be better in a next version.
- During decoding of a conax channel, the MultiEmu menu acts very slow, same problem.
- I don't know yet how to write to the flash directly from the program, so every time
you turn on the receiver, you have to upload the latest k*ys in case they have changed.
k*y updates:
- Currently there is no auto-update, need some extra information for that Smile
Updating k*ys is possible through a simple smartcard and the me_upd program,
put me_upd.hex in the flash of the smartcard and the k*ys in the internal eeprom,
read the me_upd.txt file for information.
Put the smartcard in the module/receiver and the k*ys will be uploaded.
Known bugs:
none Smile
Thanx to all the great guys/girls who took so much effort in investigating the matters and solving it.
English section also.
History:
Version 0.3.4
- Release version
LOAD WITH CAS INTERFACE ONLY BIN FILE WILL BE OK!
