Enigma 2 Nightly Build: 0.7.0 version
edilit
הודעות: 436
הצטרף: 26 נובמבר 2005, 14:00
שליחה על ידי edilit »
Originariamente inviata da README
release 0.7.0
- fixed mute volume on channel change
- mute over SPDIF is now working
- added mp4 runtime detection
- added http mp4 streaming
- added m2ts file
- added stty
- added netstat
- added traceroute
- added grab for GUI screenshots (it does not work with live-tv screenshots)
- fixed many bugs on video drivers (don't remember all because most of drivers code were completly reviewed)
- applied better quality on video drivers (IMHO now on sd channels is really better than before)
- fixed many bugs on audio drivers (most of them on codec side)
- fixed (??) snr/agc value on tuners (especially in the sharp tuner)
- fixed bug on starting network at boot
- changed bootlogo with a new default
- reorganized general driver structures
- fixed subtitles *.srt and *.ssa when there is '.' char in the file name
- fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at enigma2 boot)
- fixed a bug that causes DNS to be rewritten at reboot or at network restart when dhcp is activated on the router/net (if you have dhcp activated dns will be always given by dhcp server)
- fixed a bug that make dhcp always activated
- fixed record from standby
- fixed record from deep-standby
- fixed timer bug for record scheduled events
- fixed volume bug on web-interface
- fixed menu factory reset (thanks skaman)
- fixed panscan mode on almost all possible cases
- fixed audio volume on SCART wich was lower than HDMI
http://enigma2.sifteam.eu/index.php?...Build%200.7.0/
אשמח לשמוע מי ניסה את זה
ahgi
הודעות: 3742
הצטרף: 07 ינואר 2004, 17:38
שליחה על ידי ahgi »
התקנתי את גירסאת הפלאש:
Siffteam Enigma2 Nightly Build 0.7.0 Flash
האימג' עובד אצלי כבר כמה ימים ויש שיפור ניכר מאד
יתרונות:
כל הבעיות של האימגים הקודמים תוקנו
אין יותר מסך ירוק
המעבר בין ערוצי HD לSD ולהפך חלק ללא עצירות בתמונה או הפרעה אחרת
חסרונות:
בגירסה הזו תפריט ה ADDON צריך להתקין אותו ידני הוא מגיע בצורת פלאג אין
(יצאה גירסה 7.1 שיש בה את תפריט ה ADDON מובנה באמיג')
מסקנה :
יש עוד מה לשפר אבל אניגמה 2 סוף סוך יציבה בממיר הזה 250HD
לשמחתי
אפשרי להעביר את הבוקטים מהדרים בוקס 500 הישן לממיר HD :D
סוף סוף
מילה טובה לא עולה כסף
נשמע שבאמת יש התקדמות סוף סוף..
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
ההתקדמות כבר נמצאת בשלבים מתקדים עם גרסת ה EXTREME של SIFTEAM שעובדת ממש טוב , אבל כרגע יש מספר מערכות שעובדות רק באופן ידני, אבל בהחלט אימג משופר בצורה בלתי רגילה
