CUBEREVO DGS release r10336: ( 08/Aug/2009
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
This README is for CubeRevo HD model series.
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a fo rmat that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom servic e and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
3. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
2. The timeshift function of multiroom will release on the next.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function
הודעות: 30817
וואוו שליטה מהאיפון
Jaaz
הודעות: 174
הצטרף: 23 יוני 2009, 09:47
שליחה על ידי Jaaz »
וכרגיל, כעבור כמה ימים Sifteam הוציאו את המוד שלהם.
מה שאני לא מבין זה מדוע העדכון הזה לא מופיע באתרי ה- FTP של החברה ושל Sifteam, ובכך היו מאפשרים לי לעדכן ישירות מהממיר ללא הפרוצדורה עם ה- USB.
אגב, עובד יופי.
7W-4W-4.8E-13E-16E-19.2E
1.2 meter dish
הודעות: 2791
עקרונית אין קשר בין SIFTEAM לבין DGS או IPBOX, אבל יש קשר עקיף בפיתוח התוכנה
Jaaz
הודעות: 174
שליחה על ידי Jaaz »
מה הכוונה אין קשר?
Sifteam מחכים ליציאת גרסה של DGS, ותוך יומיים שלושה בממוצע מוסיפים עליה את המוד הקבוע שלהם.
לכן כל גרסת sifteam תמיד משוייכת לגרסת DGS.
יותר קשור מזה, לא נראה לי אפשרי..
1.2 meter dish
הודעות: 2791
כמו שאין קשר ישיר בין קבוצת הפיתוח של גמיני ו חברת DM ככה אין בדיוק קשר בין SIF לבין IPBOXDGS
אל תשכח שקבוצות אלו מייצרים אפליקצה שנחשבת לא תמיד חוקית ולכן לחברות היצרניות אין קשר ישיר עם אותם מפתחים
Jaaz
הודעות: 174
שליחה על ידי Jaaz »
עדכון שלי -
הגרסה הזאת בשילוב mbox 0.4.0023 מייצרת הרבה פריזים, ווידאו לא יציב.
חזרתי לגרסה הקודמת (גם של sifteam), חזר לעבוד מצוין.
אני אחכה לגרסה הבאה..
1.2 meter dish
marcelos
הודעות: 1028
הצטרף: 11 פברואר 2005, 09:54
מיקום: קרוב, בסביבה
שליחה על ידי marcelos »
JAZZ עם איזה גרסא אתה עכשיו??
ואם אופציה ההקלטה עובד טוב??
+100 to 1W
+120 to 19E 7E
Jaaz
הודעות: 174
שליחה על ידי Jaaz »
אני עם Sifteam-9580 של DGS.
ההקלטה עובדת טוב, למעט הקלטה דרך ה- EPG. (הבנתי שזה באג ידוע).
יש לכוון timeshift פעיל בתפריט ההקלטה.
גם הקלטה וגם timeshift עובדים לי מצוין.
מה שלא עובד לי עם הגרסה הזאת הוא ה- webtv, אבל אני מוכן להתפשר עליו בשביל כל השאר.
1.2 meter dish
marcelos
הודעות: 1028
מיקום: קרוב, בסביבה
ואיך האמולטורים עובדים?
MGCAMD בעיקר...?
+100 to 1W
+120 to 19E 7E
Jaaz
הודעות: 174
שליחה על ידי Jaaz »
mbox עובד לי יופי, אין לי מושג ירוק לגבי MGCAMD..
1.2 meter dish
