INCUBUSCAMD 0.85
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
V0.85
- deleted old priority system for caid, now will be used firstly the prio and then a cycle selection
- SID in hex value instead of dec one
- fixed some bugs on caid ecm parsing
- fixes for stability/less-crashes (crashes were made by the pmt handling, using pmt file wich the writes is slower than the channel change,
now should be fixed in almost all cases)
- still open the 2.1.1 protocol support and previous version
- fixed a bug on reading keys for the internal emulator, now also unsupported softcam.key files are skipped in the unknown fields
(read the softcam.key file to see how to build a new one)
I think i need to explain something about last releases:
incubusCamd is born for cuberevo models, no other models are supported by my choiche.
I saw many tries to crack the cam... well, do as you like but do not associate stability problems to the cam, because stability
is tested only on cuberevo. Bef ore open your mouth close your eyes and hope!
If you want to report any kind of bugs use usual international places, i will read them, but report only cuberevo bugs.
I don't mind about other boxes and on cuberevo for sure the connection shouldn't be lost after few minutes, this is caused by a low
level management of the protocol wich causes many bugs on all other boxes.
So to all people claiming about incubusCamd: I hope you could live 100 years to be able to ever see me enjoy.
