יש למישהו כרטיס אירדטו2 שפג?
Raviv
- הודעות: 893
- הצטרף: 26 דצמבר 2003, 01:51
- מיקום: מרכז-אירופה
it can be reactivated! I can either post the info about it or work on it. a blocker (piece of hardware) is needed
Raviv
- הודעות: 893
I meant to ask if someone has an expired card of Irdeto2 (yes, also Showtime or ADD). This guy posted the way to do it with cards v.2 and 2.1 (saw that higher they have some problems). the idea is to log the activation stream (first time of subscription) so this can be used to reactivate the card once it is about to expire. with expired cards it may be harder or impossible but less risky since people are willing to play with the card. this guy posted a large file of logging for Showtime so some work needs to be done on it. Apperentely, since he posted the forum got legal notices from Irdeto so they stopped the discussion but I got it on time. I have never done this thing (made Seca mosc; never had Ird2 card and can hardly receive Showtime or ADD on 7w) but can help you if you like. I can also send you the files posted and a summary of the discussion. maybe you can ask about it also at the arab forum.
- איש המציאות
- הודעות: 792
- הצטרף: 23 דצמבר 2003, 09:33
- מיקום: חיפה
hi raviv !
if you can post it on this thread ,
i would appreciate it !
thanks!
Amir.
thanks!
Amir.
my collection so far :
Raviv
- הודעות: 893
Amir, you know what? lets do a deal. If you can find me a couple of expired (dead or nearly dead) cards of Showtime (Ird2) I will experiment on them. If I succeed I will keep one card and return the other (or more) to you plus I will post the exact procedure [and if I dont succeed I will return all the cards plus the exact procedures I tried on them]. I have all the hardware and such a challenge excites me. just make sure the cards are from 2.1-2.2 series (issued not later than mid 2002). thanx
רפאל
- הודעות: 292
- הצטרף: 07 פברואר 2004, 20:40
