אימגים חדשים לדגמי 9000/900HD
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
פורסם היום באדיבות האתר SAT UNIVERSAL, שני אימגים חדשים למערכות IPBOX (ABCOM )
דגמי IPBOX9000HD
IPBOX900HD
Changelog:
add:
- usb automount function.(9000HD only)
- Turkish translation.
- DB updated to R7327. Database will be updated automatically.
- sorting function in PIP sub-channel list
- recording file format was changed.(will be applied from new REC. but old format will be played too)
- using HDD if download large s/w image(for example usb_all_noboot.img).
Need special server configuration.
- switch to live when end of file playback
- improve webinterface function
fixed,modify:
- modify tp information. Hotbird 11278 (need DB update)
- modify many tp information in Turky Sat (need DB update)
- Fixed ORF1HD freeze
- Premiere EPG : show subfeed epg in mainfeed list epg. epg duplication problem.
- CAM work on backgroud recording.
- panic if enter wrong format in IP address.
- remove NTSC mode in AV setting.
- EPG related panic on some channel
- support 12h time mode in EPG
- random panic when play recorded file.
- improve performance on open FAV menu
- clear video plan when channel change.
שימו לב :
Warning: If you use USB HDD , you need connect and switch ON HDD before STB boot.
This version supported only ext2 and ext3 filesystem, HDD with this filesystem will not be formatted.
If you format USB or e_SATA HDD , STB use ext3 filesystem.
This version doesn´t supported FATxx  file system for photoshow and MP3 playback from USB device saved on PC!
If you want see Photos, copy pictures to /media/photo.
ftp login/password:  root/ipbox
Software upgrade from USB memory stick (host):
• backup important data from memory stick before try to update. Remove all data from it.
• copy "usb update.img" image to USB memory stick
• run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen.
• turn off the stb(Standby + OK) and insert the memory stick.
• press and hold Standby button until front display shows “BOOTING” and press UP key
              (on the front side of the box, not on RC), then front display shows "USB UPGRADE" message..
• uboot will update s/w with usb_update.img from memory stick
• Wait until DONE message displays. Restart your receiver.
חשוב לשים לב למה שרשום בציטוט
אני מעלה את הקבצים לZSHARE כי כל גודל הוא מעל 20 מגה וחבל על המקום פה
AB_900HD_r7473_260608_usb_all_noboot.zip
[URL=http://www.zshare.net/download/143633628abb8ffe/]ab_900hd_r7473_260608_usb_all_noboot.zip [/URL
ab_9000hd_260608_r7473_usb_all_noboot.zip]
