גמיני 360
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Gemini2 v3.6:
Technical Infos:
* Engima from: 19.06.2008
* Busybox 1.0.1
* Tuxtxt 1.95
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP (DM7025)
* RED - Record
* GREEN - Quickbutton / Subservices
* Yellow - Timeshift
Addons:
* Own Addon-Server via internet.
* Download and installation of additional features via internet from Gemini server.
* Use your own Personal addon server (configure it in /etc/useraddon.xml).
* Create your own Satellites.xml which only includes the satellites you need.
Camd:
* Assign of different Camd's to Stations/Providers (AutoCam).
* Change of the name and different functions over own menu.
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Device Settings->Printer (LPD), FAQs in the database).
* Dropbear (ssh) now switchable (BP->Extras->SSH).
* Upnp Server / Client
* automount, examples in /etc/automount.conf. Devices, NFS or CIFS get automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found at BP->Extras->Automount).
* Inadyn (Daemon for various DYNDNS-Services).
* little Apache (HTTP-Server based on HTTPD).
* NFS-Server (based on the NFS-Kernel-Modul).
* Editor to configure Cron-Deamon
Infobar / OSD:
* Provider and Sattelite will be showed in the Infobar (depends on the skin).
* EMM, ECM or "ExpertInfos" Display switchable.
* Picon (displays the station logo)
* Show Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
* Spinner (response time now adjustable, 0 is off)
* Picons can be changed between Gemini and DMM format
* the position of the infobar can be changed
Files / Devices:
* Support for CDROM/DVD no matter if it is IDE ur USB
* HDD- temperature and performance visible in the menu.
* HDPARM values for harddisks disk can be changed by menu.
* SWAP setup and start automatically.
EPG:
* EPG-autosav- Saves the EPG data in a defined time
* additional EPG-Infos (BP -> Info)
* Duration of current Event in the programm overview ( BP -> Info -> EPG)
* EPG-Serch. Search by Title, description or own text.
Extra:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s).
* Weather Plugin with 10 days forecast.
* RSS/RDF reader with TOP list from RSS-scout.
* Webcam-Viewer with FullScreen mode.
* bell (plays mp3s on a fixed time)
* System Info: Many extra box infos like stream-rates, kernel-, memory- and prozessinfos.
* Own Scripts can be started via Blue Panel.
* Kernel modules can be reload separately.
* Password can be changed by menu.
* EPG Cache and EPG Refresh (updates the EPG in the night) adjustable over BP.
* flashing clock when recording in standby.
* Calendar for the iCalendar format + Reminder (supported by MAC, KDE, Thunderbird, Google calendar, Rainlendar…) , Standard-folder is /etc/ical.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* eMail-Checker (Overview of your POP3 or IMAP accounts + SSL)
* overwiev of the different Cryptingsystems which the actual station uses.
* Quickbutton
* Turning of pictures, also automatically by EXIF data.
* "The GP2 Controlr" Firefox Extension to access functions of the Box.
* ReZapp, Switch back to a channel on a fixed time (BP-> Extra-> ReZapp)
New:
* internal changes for EMM and ECM (channel and encryption infos)
* partially new structure of the Blue Panel (e.g. systeminfos can now be found here: Menu -> Information)
* Device Manager is still beta (format, mount and other functions)
* Kernel-Modul-Menu can now be configured using the file "/etc/init.d/gmodules"
* HDTV-Logo in the Infobar
* Summary of the HDTV-Channels in the Channellist->Satellites
Fix + Updates:
* fuse, libupnp und ushare-9.8 at ushare-1.0
* satellites.xml und loader
* eMail-Checker
* see CVS
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
http://www.i-have-a-dreambox.com
geosat
הודעות: 1340
הצטרף: 23 דצמבר 2003, 12:30
שליחה על ידי geosat »
האם M8 הצלחת להתחבר ל כונן USB.? אפשר לקבל הדרכה מדויקת
קודם שיהיה לו 800...
geosat
הודעות: 1340
חבל מאוד שאין לו, בכל זאת עזר לי
אתה שואל אותה שאלה כבר איזה חמש פעמים וכשאני עונה לך אתה לא מאמין.
geosat
הודעות: 1340
יש שןרה ב EXTRA SETTING ולא יודע מה לעשות איתה
USB MANEGER לא מצאתי
אולי תתין רמז יותר מדויק ןאז אוכל לחבר כונן USB
עשיתי מה שאמרת לי ואין חיבור לכונן USB
הדיסק שלך עם חיבור מתח חיצוני?
ב 3.6 הם הוסיפו בתפריט הכחול את שורה 5 devices manager. זה אמור להיות שם.
geosat
הודעות: 1340
מצטער לא הייתי בבית, תודה ניבדוק
nira
הודעות: 457
הצטרף: 10 יוני 2006, 12:25
מיקום: חיפה
שליחה על ידי nira »
י א @ 20/6/2008, 16:48 כתב: קודם שיהיה לו 800...
הוא לא צריך 800!
7025 מספיק, ולמיטב ידעתי יש לו.
תודה מראש
ניר א.
תסלח לי, אבל להגיד שדרים 800 מתחמם אתה צריך שיהיה לך דרים 800 כדי שתוכל לחוות דעה אמיתית ולא שמועות מאחרים. גם לגבי חיבור דיסק חיצוני, יש הבדלים מהותיים בין 7025 ו 800.
הדבר היחידי שזהה ביניהם זה שהם עובדים אניגמה 2.
nira
הודעות: 457
מיקום: חיפה
שליחה על ידי nira »
י א @ 21/6/2008, 11:37 כתב: תסלח לי, אבל להגיד שדרים 800 מתחמם אתה צריך שיהיה לך דרים 800 כדי שתוכל לחוות דעה אמיתית ולא שמועות מאחרים. גם לגבי חיבור דיסק חיצוני, יש הבדלים מהותיים בין 7025 ו 800.
מיתחממם?
מה הקשר?
השאלה קשורה להפעלה ושימוש בגימיני 3.6,
פרט לשנוי מינורי בהגדרות לווינים ה 7025 ו 800 זהה לגמרי בכול התפריטים והפונקציות.
מי מאומר ש "הדבר היחידי שזהה ביניהם זה שהם עובדים אניגמה 2." צריך להשלים הרבה חומר בלימוד UNIX.... מדובר בלב מערכת הפעלה, זה מה שגורם למכשיר להיות מתקדם בדור....
תודה מראש
ניר א.
טוב סליחה - אלך ללמוד..
אני מבין שגם לך יש דרים 800 בבית?
nira
הודעות: 457
מיקום: חיפה
שליחה על ידי nira »
לא, אין לי דירם 800 בבית, ולמען הדיוק אין לי כבר חודשים ממיר מכול סוג שהוא B) ...
תודה מראש
ניר א.
