שמות נוספים ל-Apex 4900
boaz
הודעות: 82
הצטרף: 27 אפריל 2008, 09:34
שליחה על ידי boaz »
מצ"ב שמות נוספים לדגם Apex 4900:
Datacom DT-103
Drake ESR-D103
Digimax 9010
Changhong DVB-S6500N
* נעשה ע"פ תמונות בלבד
boaz
הודעות: 82
שליחה על ידי boaz »
תכונות של Apex 4900
ADVANCED FEATURES
• Multi-Mode auto searching satellite programs (AUTO/FTA/Network/TP)
•Maximum storage 3000 Channels,2000 Transponders,150 Satellites
•EPG
•Adjustable transparence OSD
•Alternation of the OSD colour
•Image magnification through Zoom
•4 user defined Favorite groups with user-friendly editing functions
•Multi-mode search
•Teletext by VBI insertion
•DiSEqC 1.0 and DiSEqC 1.2 control compatible.
•Real-time antenna signal strength indicator.
•Still Picture
•Recall
•Timer
•Telephone Directory (optional)
•Video Games (snack, gobang) (optional)
BASIC FEATURES
•Free-to-Air Compatible
•High Sensitiveness, Low Eb/No Tuner
•Fully DVB-S/MPEG2 Compliant
•SCPC/MCPC, C-band/Ku-band Compatible
•Teletext Support(VBI insertion)
•Multi-Language OSD
•13V/18V, 22KHz , DiSEqC1.0, DiSEqC1.2 Switching
•Quick Channel Switching
•Parental Lock Function
•Automatic PAL / NTSC Detection
•Satellite signal loop through
•Favorite channel function with 4 Fav List.
•RF output, AV output, RF in.
•Convenient software up-grading(DFU&DFA) – PC to Receiver, •Receiver to Receiver.
boaz
הודעות: 82
שליחה על ידי boaz »
נתונים טכניים
TUNER
Satellite IF Input 950 ~ 2,150 MHz
Input impedance 75 Ohmios
Signal Level -65 dBm~-25 dBm
Connector F type, Female, Loop Through
LNB power supply 13/18V/OFF, MAX.400mA
Band switch 22KHz Tone
Demodulation
Standard DVB-S EN300 421
Waveform QPSK
Symbol rate 2~45Mbps
Roll off factor 0.35
Reed Solomon decoder RS232
Code rate 1/2, 2/3, 3/4, 5/6, 7/8
Video
Standard CD ISO/IEC 13818-2, MPEG-2 MP@ML
Video aspect ratio 4:3, 16:9
Video system PAL and NTSC
Audio
Standard ISO/IEC 11172-3
Audio decoder MPEG-1 Layer I and II
Audio channel Mono, Dual-channel, Stereo, Joint Stereo
Volume control 32 Levels adjustment
Connector
RF output 21-69 CH with PLL
Audio output 4 X RCA
Video output 2 X RCA
Scart terminal 1
General Data
Operating Temp. 0º ~ 40º C
Power supply AC 90 ~ 260V ,50~60Hz
boaz
הודעות: 82
שליחה על ידי boaz »
תוכנות PC עבור Apex4900
ספר המכשיר (פורמט PDF) - מסכי ה-menu נראים שונה מזה של ה-Apex!!!!
באתר drake יש תוכנות נוספות.
שוב, לא בדקתי עדיין אם מתאים ל-Apex4900!!! - אם משהו מכיר/יודע שיעדכן
הודעות: 2584
הצטרף: 29 נובמבר 2004, 23:15
שליחה על ידי צור .א »
תוכנת המכשיר הנ"ל יותר נחמדה משל אפקס 4900.השאלה אם באמת החומרה הקיימת מתאימה,ותקבל את התוכנה של דרייק?
ומה עם עידכון תוכנה לפתיחת ערוצים מקודדים,ואיפה היא מופצת?
זהירות לפני שדופקים את המכשיר.
boaz
הודעות: 82
שליחה על ידי boaz »
שלום לכולם,
נראה לפי חיפוש באינטרנט שיש הרבה תוכנות/עידכונים עבור Digimax 9010.
בדקתי עידכון עבור ה-Digimax 9010 עם עידכון האחרון שנמצא בדביק עבור ה-Apex4900, ונראה ששנהם מתחילים באותו אופן:
081204 NEC EMMA2L Ref Ver00.00081204
