גמיני 4.40
קבצים ולינקים המיועדים ל 7000 בלבד
m8m8
הודעות: 10693
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 » 30 מאי 2008, 15:45
Gemini v4.4:
Technical Infos:
* Enigma of: 27.05.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Inadyn (Daemon for different DYNDNS-Services)
* Settings for syslogd
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* Random function for all kind of soundfiles
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
New:
* added rotation for all kinds of pictures. Also automatic rotation using EXIF (must be activated in the menu)
* Re-Zapp, sitching back to the actual Service after X-minutes (BP -> Extras -> Re-Zapp)
* Show wehter the box is an original Dreambox or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
* Recording into differnt folders (Settings are in the Timer-Menu)
* Flashing LED´s while rcording for boxes without Display can be activated in BP -> Extra -> Recording)
* Autosave for EPG-Cache (BP -> Extra -> EPG-Settings)
* Duration of current Event in the programm overvie ( BP -> Info -> EPG)
* EPG-Refresh Based on Enigma-Timers (BP->Extras, Beta)
* In the Information menu own matrix for network Devices
* create own weather.xml for your Country in RSS/Weather Addon
* generall information of the EPG-Data (BP -> Info -> EPG)
* the period for the EPG-Data can now be changed (BP-Extra->EPG-Settings)
Fix + update:
* changed the routines for rotating pictures. You now can countinue the rotation using the buttons <>
* Fixed the EGP-Display in the overview when using several languages.
* have a look in the CVS
Interfaces WebIF:
********127.0.0.1/cgi-bin/GeminiInfo
********127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
********127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
********127.0.0.1/cgi-bin/InitCam
********127.0.0.1/cgi-bin/ResetCam
********127.0.0.1/cgi-bin/setKey?typ=STR&...test&val=blabla
********127.0.0.1/cgi-bin/getKey?typ=INT&...itedvb/int-test
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk.
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background. We assume no liability for direct or indirect damage.
Thanks a lot and have fun
Your Gemini-Team
