חבילה HD12.5W
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
תדר
11185V SR-13757 FEC 2.3 MPEG 4 8PSK DVBS2
'National Geographic Channel Portugal',
'National Geographic Channel HD UK
National Geographic Channel Türkiye
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
Program Association Table
PAT Version Number: 25
Transport Stream ID: 5 (0x0005)
PMT PID 16 (0x0010) - Network
PMT PID 701 (0x02bd) - Program 701 Nat Geo HD
PMT PID 702 (0x02be) - Program 702 NAT GEO PORTUGAL
PMT PID 703 (0x02bf) - Program 703 SET PORTUGAL
PMT PID 704 (0x02c0) - Program 704 Bainet Sat
PMT PID 705 (0x02c1) - Program 705 National Geographic Turkey
Program Map Table(s)
Network PMT Entry - carried on PID 16 (0x0010)
Program Number: 701 Nat Geo HD
Descriptor: Maximum Bitrate Descriptor
Maximum bitrate: 1490300 bytes per second
Descriptor: Smoothing Buffer Descriptor
SB Leak Rate: 625 SB Size: 1024
Descriptor: System Clock Descriptor
External Clock Reference: 0 Clock Accuracy Integer: 2 Exponent: 1
Stream Type: 0x1b H.264 Video PID 7011 (0x1b63)
Descriptor: AVC video descriptor Descriptor
64 00 28 00 d.(.
Descriptor: Data Stream Alignment Descriptor
Alignment type: video access unit
Descriptor: Stream Identifier Descriptor
0a .
Stream Type: 0x06 PCM Audio PID 7012 (0x1b64)
02 .
Descriptor: Registration Descriptor
Format identifier: 0x42535344 (BSSD)
Descriptor: ISO639 Language Descriptor
Language: eng
Audio type: hearing impaired
Stream Type: 0x06 PCM Audio PID 7013 (0x1b65)
03 .
Language: eng
Stream Type: 0x11 MPEG-4 Audio PID 7014 (0x1b66)
Descriptor: MPEG-2 AAC audio Descriptor
01 02 00 ...
35 5
Language: eng
Audio type: undefined
Stream Type: 0x06 Dolby AC3 Audio PID 7015 (0x1b67)
AC3: Bitrate 448 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 3/2 5 L, C, R, SL, SR
AC3: Center Mix Level -3.0 dB Surround Mix Level -3.0 dB
AC3: LFE Mode On Dialogue normalization -27 dB
37 7
Format identifier: 0x41432d33 (AC-3)
Language: eng
Descriptor: AC3 Audio Descriptor
Flags: AC3 Type: True BSID: True Main ID: True ASVC: True
AC3 Type: 1
BSID: 1
Main ID: 6
ASVC: 7
Program Number: 702 NAT GEO PORTUGAL
Stream Type: 0x1b H.264 Video PID 7021 (0x1b6d)
H.264 Video: Resolution 720 x 576 Interlaced: 0
4d 40 28 3f M@(?
Descriptor: AVC timing and HRD Descriptor
fe ef ..
Stream Type: 0x03 MPEG-1 Audio PID 7022 (0x1b6e)
MPEG1 Audio: Bitrate 256 Kbps Sample Rate 48 KHz
MPEG1 Audio: Layer II Mode Stereo
Language: por
Stream Type: 0x03 MPEG-1 Audio PID 7023 (0x1b6f)
Language: eng
Program Number: 703 SET PORTUGAL
Stream Type: 0x1b H.264 Video PID 7031 (0x1b77)
4d 40 28 3f M@(?
fe ef ..
Stream Type: 0x03 MPEG-1 Audio PID 7032 (0x1b78)
Language: spa
Program Number: 704 Bainet Sat
Stream Type: 0x1b H.264 Video PID 7041 (0x1b81)
4d 40 28 3f M@(?
fe ef ..
Stream Type: 0x03 MPEG-1 Audio PID 7042 (0x1b82)
Language: spa
Program Number: 705 National Geographic Turkey
Stream Type: 0x1b H.264 Video PID 7051 (0x1b8b)
4d 40 28 3f M@(?
fe ef ..
Stream Type: 0x03 MPEG-1 Audio PID 7052 (0x1b8c)
MPEG1 Audio: Bitrate 128 Kbps Sample Rate 48 KHz
Language: tur
Stream Type: 0x03 MPEG-1 Audio PID 7053 (0x1b8d)
Language: eng
Stream Type: 0x06 Teletext/VBI PID 7054 (0x1b8e)
Descriptor: Teletext Descriptor
Language: FRE Type: Initial Teletext page Magazine: 0x01 Page: 0x01
Conditional Access Table
CAT Version Number: 22
Descriptor: CA Descriptor
CA System ID: 1280 (0x0500) France Telecom
CA PID 71 (0x0047)
CA private data: 13 01 20 14 03 02 1a 10
Service Description Table
SDT Channel 701
Service Name: Nat Geo HD
Provider Name: Overon
Original Network ID: 8916 (0x22d4)
SDT Channel 702
Service Name: NAT GEO PORTUGAL
Provider Name:
SDT Channel 703
Service Name: SET PORTUGAL
Provider Name:
SDT Channel 704
Service Name: Bainet Sat
Provider Name:
SDT Channel 705
Service Name: National Geographic Turkey
Provider Name:
MPEG-2 Statistics
Table Sections Processed CRC Errors
PAT 7.5k 0
CAT 7.5k 0
PMT 2.9k 0
NIT 0 0
SDT 7.5k 0
EIT 0 0
Continuity errors: 0
TEI errors: 0
Calculated multiplex rate: 26435334 bps
General Information
Source: TechnoTrend Budget DVB-S2
Tuner: 11185 MHz V/R 13657 DVB-S2
Signal: Locked SNR 11.4 dB
Network Type: DVB
Run Time: 000:09:24
PID Usage Chart
0 (0.08% ~ 0.02 Mbps)
0 MPEG-2 Program Assocation Table
1 (0.08% ~ 0.02 Mbps)
1 MPEG-2 Conditional Access Table
17 (0.08% ~ 0.02 Mbps)
17 DVB Service Definition Table
71 (0.37% ~ 0.10 Mbps)
71 EMM for system ID 0x0500 (1280) France Telecom
701 (0.01% ~ 0.00 Mbps)
701 MPEG-2 PMT for program 701
702 (0.01% ~ 0.00 Mbps)
702 MPEG-2 PMT for program 702
703 (0.01% ~ 0.00 Mbps)
703 MPEG-2 PMT for program 703
704 (0.01% ~ 0.00 Mbps)
704 MPEG-2 PMT for program 704
705 (0.01% ~ 0.00 Mbps)
705 MPEG-2 PMT for program 705
7011 (19.15% - 5.06 Mbps)
7011 H.264 Video for program 701
7012 (8.96% ~ 2.37 Mbps)
7012 PCM Audio for program 701
7013 (8.96% ~ 2.37 Mbps)
7013 PCM Audio for program 701
7014 (0.28% ~ 0.07 Mbps)
7014 MPEG-4 Audio for program 701
7015 (1.78% ~ 0.47 Mbps)
7015 Dolby AC3 Audio for program 701
7021 (7.49% - 1.98 Mbps)
7021 H.264 Video for program 702
7022 (1.01% ~ 0.27 Mbps)
7022 MPEG-1 Audio for program 702
7023 (1.01% ~ 0.27 Mbps)
7023 MPEG-1 Audio for program 702
7031 (9.82% - 2.60 Mbps)
7031 H.264 Video for program 703
7032 (1.01% ~ 0.27 Mbps)
7032 MPEG-1 Audio for program 703
7041 (9.78% - 2.59 Mbps)
7041 H.264 Video for program 704
7042 (1.01% ~ 0.27 Mbps)
7042 MPEG-1 Audio for program 704
7051 (4.36% - 1.18 Mbps)
7051 H.264 Video for program 705
7052 (0.50% ~ 0.13 Mbps)
7052 MPEG-1 Audio for program 705
7053 (0.50% ~ 0.13 Mbps)
7053 MPEG-1 Audio for program 705
7054 (0.14% ~ 0.04 Mbps)
7054 Teletext/VBI for program 705
8191 (23.62% ~ 6.24 Mbps)
8191 MPEG-2 NULL Packet
