ג'מיני 4.20
- הודעות: 30820
Gemini v4.2:
Technical Infos:
* Enigma of: 17.12.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG´s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Support for OGG/Vorbis
* Random function for MP3 and OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s)
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
New:
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* centralized services and deamons in one Menu
* Editor to configure Cron-Deamon
* OGG-Vorbis is no more included. Please install as addon
* Support for FLAC and WAV (please install both codecs as addon, both are beta)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Fix + update:
* see CVS
* internettime (no reboot needed)
* extended the WebIF with 2 functions:
setKey and getKey reads or writes Values from the Enigma Config.
http://127.0.0.1/cgi-bin/setKey?typ=STR ... val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=INT ... b/int-test
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
להורדה
Technical Infos:
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
Addons:
Camd:
Files / Devices
* Backup function
Extras:
New:
Fix + update:
* see CVS
Interfaces WebIF:
להורדה
המאסטרו
- הודעות: 136
- הצטרף: 15 פברואר 2008, 00:10
י'א שלום לך
אני לא מצליח להתקין את הקובץ הזה בדרים 7020 עם התוכנה של. FlashWizard כנראה בגלל שלקובץ
הזה יש סיומת של..nfi..זה נקרא :
gemini-420-dm7020-200712171831.nfi
מה צריך לעשות כדי שאפשר יהיה להתקין את הקובץ הזה בדרים 7020 ? האם צריך לתת לו סיומת של img דרך תוכנה כולשהי ? או שיש דרך כולשהי לשנות אותו דרך התוכנה של FlashWizard
- girobert
- הודעות: 663
- הצטרף: 05 יוני 2006, 12:53
המאסטרו
- הודעות: 136
girobert שלום
האם אתה יכול להגיד לי איך עושים התקנה של אימג' ג'ימיני בדרים 7020 דרך האקספלור ?
האם צריך לעשות בדרים 7020 פקטורי ריסט לפני ההתקנה של האימג' ולכבות אותו מהכפתור האחורי ?
איזה כתובת IP צריך לשים בדפדפן כדי להתחיל התקנה והאם אכן מדובר על אותו קובץ שרשמתי אתמול
- girobert
- הודעות: 663
יש לך בלינק הבא הסברים איך לטעון IMAGE דרך הדפדפן :
http://www.dream-multimedia-tv.de/dm702 ... rowser.php
בהצלחה !
בהצלחה !
המאסטרו
- הודעות: 136
