Gemini v4.20 DM 500S Announcement
totor
הודעות: 76
הצטרף: 12 יולי 2007, 15:19
שליחה על ידי totor »
Gemini Project 4.20 DM 500S
Salut a tous
Gemini v4.20 DM 500S Announcement !!!
In future the Images for for the Dreambox (7000, 5620 and 500) will only be released 1 or 2 times a year. Then of course based on an actual CVS.
Gemini v4.2:
Technical Infos:
* Enigma of: 14.12.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Inf***r / OSD / Skin / Background-Pictures:
* Position of the Inf***r can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Inf***r (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG´s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Support for OGG/Vorbis
* Random function for MP3 and OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s)
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
New:
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* centralized services and deamons in one Menu
* Editor to configure Cron-Deamon
* OGG-Vorbis is no more included. Please install as addon
* Support for FLAC and WAV (please install both codecs as addon, both are beta)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the inf***r (eLabel-Name = geminievent)
Fix + update:
* see CVS
* internettime (no reboot needed)
* extended the WebIF with 2 functions:
setKey and getKey reads or writes Values from the Enigma Config.
http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any k*ys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
h**p://www.zshare.net/download/58094783e7efc8/
humax
הודעות: 574
הצטרף: 09 ינואר 2004, 21:59
שליחה על ידי humax »
לא ניתן על DM 500 |לא|
יוסף1
הודעות: 142
הצטרף: 24 ינואר 2007, 13:09
שליחה על ידי יוסף1 »
לא ניתן מה ?
:rolleyes:
humax
הודעות: 574
אני לא הצלחתי להתקין 4.2 על DM500 |לא| ,
BMWH1
הודעות: 878
הצטרף: 19 מאי 2006, 14:56
שליחה על ידי BMWH1 »
אין צורך כי אין הבדל בין 4.2 ל3.6 אני כרגע עם 3.6.
יוסף1
הודעות: 142
דרך המסך הכחול לא הצלחתי
דרך DCC כן הצלחתי.
simonedo
הודעות: 17
הצטרף: 16 פברואר 2004, 08:49
מיקום: ראשון לציון
שליחה על ידי simonedo »
האם ההתקנה מוחקת את ההגדרות שיש לי עכשיו במכשיר?
אם כן מה צריך לגבות
אם לא אז אין בעיה
הודעות: 30809
שידרוג דרך DCC לא מוחק.
