גמיני 4.00
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
Gemini v4.00:
Technical Infos:
* Enigma of: 24.08.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG´s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Support for OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s)
* System Info: Many extra box infos like stream-rates, kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
New:
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* Infoszeile im Sendermenü jetzt wie in Enigma2.
* Infobar in the channelmenu is now like in E2.
* Changed the addon routines. There will be a preview available by many addons and skins (due to the new structure of the addons we also did the version jump)
* own RSS und Weather Plugin (for 7000 and 500 you have to install it)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* disable the TV-out (scart out) while you take a record (onle makes sense with the 500)
* Completely reworked DreamNetCast
* ECM-Expert+ now using a separate window
Fix + update:
* see CVS
nterfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background.
הודעות: 2791
הצטרף: 25 נובמבר 2006, 18:38
שליחה על ידי prince_amir »
הורדת הקובץ אימג לדריימ 500 גרסה 4
ahgi
הודעות: 3743
הצטרף: 07 ינואר 2004, 17:38
שליחה על ידי ahgi »
|כן|
מילה טובה לא עולה כסף
talsh
הודעות: 119
הצטרף: 18 אוקטובר 2006, 11:20
שליחה על ידי talsh »
טענתי אותו עם DCC ועכשיו הממיר לא עולה.
אור ירוק - אבל הממיר מת ואין פינג...
מה עושים במצב כזה?
טל.
nira
הודעות: 457
הצטרף: 10 יוני 2006, 12:25
מיקום: חיפה
שליחה על ידי nira »
מבצעים מחיקה פעמים שלוש באמצעות DREAMUP ואחרי זה מתקינים אימג מחדש באמצאות אותה תוכנה.
דרוש כבל RS232....
קיים מדריך לשימוש בDREAMUP למרות שבגדול מנתקים חשמל מעלים DREAMUP מחברים חשמל ואז אין הרבה מה לדעת....
תודה מראש
ניר א.
humax
הודעות: 574
הצטרף: 09 ינואר 2004, 21:59
שליחה על ידי humax »
עובד מצויין !!
השתמשתי ב DCC 82
DCC שומר על כל ההגדרות
ovadcad
הודעות: 170
הצטרף: 17 מאי 2007, 04:20
שליחה על ידי ovadcad »
ברצוני לעדכן את ה-drambox שלי ל- gimini 4 אך ברשותי מחשב נייד ללא חיבור סיראלי
שאלתי היא אם יש null modem עם יציאת usb שתאפשר לי לבצע עידכון ותיקון אם צריך
הבנתי שלא מומלץ לבצע את העידכון ב-DCC רק ב-DREAMUP (מצריך כבל)
nira
הודעות: 457
מיקום: חיפה
שליחה על ידי nira »
אני לא יודע למה אתם קוראים להתקן מודם ?! בכול מיקרה קיים מתאם USB ל RS232 מסוגים שונים, הפיתרון עבד לי נהדר עם 3 סוגים שונים....אני משתמש איתו בנייד של LENOVO .
תודה מראש
ניר א.
dpklain
הודעות: 8329
הצטרף: 19 אוגוסט 2005, 00:34
שליחה על ידי dpklain »
אני שידרגתי דרך ה-DCC בעבר ולא
היתה שום בעיה,להפך כל ההגדרות
נשארו.2-3 דקות של עידכון והכל מוכן
ומזומן לצפיה באימג החדש.
ראה הסבר :
http://www.sat-israel.com/Forums/index. ... opic=20977
רק ההגינות תנצח
הודעות: 2791
במקום DCC אני משתמש ב FLASHWIZARD, תמיד עובד, מנקה את זכרון בממיר.
pakwan
הודעות: 2268
הצטרף: 01 אפריל 2005, 11:12
מיקום: נתב"ג
שליחה על ידי pakwan »
prince_amir @ 2/9/2007, 09:41 כתב: במקום DCC אני משתמש ב FLASHWIZARD, תמיד עובד, מנקה את זכרון בממיר.
גם אני |כן|
talsh
הודעות: 119
התקנתי את האימאג' מחדש עם כבל null modem ו dreamup.
הכל עובד פיקס וכל ההגדרות נשמרו
קניתי את הכבל בחברה בשם TFL, רח' כנרת 15 בני ברק (ליד קניון איילון) - עלות 10 ש"ח
shaib
הודעות: 3
הצטרף: 13 אוגוסט 2007, 11:58
שליחה על ידי shaib »
התקנתי האימאג' דרך רשת אלחוטית עובד פצצה ומהיר.
פשוט להגדיר את כתובת הממיר שהוא מקבל מהראוטר
בהצלחה :rolleyes:
talsh
הודעות: 119
חבר'ה, תיזהנו עם התקנת אימאג' דרך הרשת (אלחוטית או לא).
לפעמים זה עובד ולפעמים לא. (בשתי התקנות, אחת הצליחה לי ואחת לא).
כשלא, הסיבה היא כנראה שהזכרון (Ram) של הממיר לא נקי, או שיש כל מיני services\deamons שמפריעים. Boot לפני הההתקנה יעזור, אבל לא על בטוח.
כשאתה מתקין עם dreamup דרך כבל , האימאג' מועבר עם עלית הממיר, בשלב הנכון (אוטומטית) לאחר ה boot ולכן זה תמיד עובד.
גם צוות ג'מיני עצמו ממליץ בחום להתקין רק עם dreamup ועם כבל.
bogart
הודעות: 76
הצטרף: 01 יולי 2006, 15:53
שליחה על ידי bogart »
אפשר להעלות את הקובץ מחדש.
אני מקבל הודעה שהקובץ פגום.
DREAMBOX 500S - DREAMBOX 800 HD
DISHE 120 cm - 4 LNB
E" 13.0 - E" 16.0 - E" 4.8 - W" 7.0
ההורדה מהקישור שבהודעה השנייה תקין
bogart
הודעות: 76
עכשיו תקין
