Output of the general information:
1) ATR;
2) the number of map;
3) Label;
4) Ident;
5) PPUA;
6) GEO;
7) VersionCard (version of map);
8) Classes(podpiski); 9) what keys and in what provider be present. For all maps (with the knowledge by the eighth of byte key):
1) addition and the removal of keys (both by the eighth of byte and with the support of the map 16- TI of byte);
2) addition and the removal of providers;
3) addition and the removal of subscription;
4) change PPUA;
5) change Label;
6) change GEO. For the old maps:
1) the discharge pin of the code;
2) it takes out keys in the pure form. For the new maps:
2) it takes out some keys in the coded form;
3) it prescribes 07 to klyuch' into selected ident;
4) it deciphers to klyuch' from the flow (you put ravine from the flow) with any apdeyte key (for all, group, individual) without the creation of base. Piratki (via2):
1) the introduction of keys. Special features:
1) not mashayet the presence of key 0B as in provider and in issuyera;
2) does not interfere the absence of keys 0F in provider so in issuyera;
3) does not interfere the presence pin of the code (it discards automatically);
4) work with USB by the programmers through adapter USB COM;
5) the determination of card to the originality (originalka or piratka).
Version 1.4...
+ remout keys in piratke!
+ are corrected errors with the input of data (very rarely they appeared, but nevertheless corrected should have been)
+ it was corrected Gluck on some maps - he does not write correct to klyuch'
+ checking to the originality of map (originalka of piratka)
Version 1.6...
Protestirovanna appeared the new version of progi(y.') of!!!!! Global change in!!!!!!!!!!
The calculator is added:
1) it considers it from any as the eighth of the bytes of khesh, dekhesh, crypts, dekript;
2) it counts from arbitrary data of khesh, dekhesh;
3) is counted the body of command CAF0 of khesh;
4) is counted the body of command CAF8 of khesh;
5) is counted the body of command CA88 of khesh, kript+dekript on EA10;
6) is counted the body of command CA18 of khesh, kript+dekript on EF08(.EF10) and EE08;
7) on points 2-6 is provided initial you khesh';
8) Boolean operations (AND.neg.not.or.khor);
9) the conversion of date in 2- X byte size and vice versa. IT COUNTS BOTH ON 8- MI to byte KEY And ON 16- TI to the byte KEY of!!!!!!!!!!!!! I.E. IS ADDED THE ALGORITHM VIA2 OF!!!!!!!!!!!!!!!!!!!!!!!!!!!
