ג'מיני 3.5
הודעות: 30816
Gemini v3.50:
Technical Infos:
* Enigma of: 06.04.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB (>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working without internal hard drive, mountpoint set to "var/mnt/hdd" and at least 3GB disk space)
* Extra menu: Settings for many features like Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Bluepanel
* Calender including reminder (can be changed via .../calendar.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket) switchable.
* Register an own addon server( useraddon.xml)
* Provider, Frequencies, kSyms, and FEC could be displayed on the Infobar (If the Skins matches this function)
* Picon implemented in Gemini
* "real" automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted (Editor within the BP-Menu)
* Dropbear is activ in all Images (SSH - Deamon)
* cifs-1.44
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar displaying)
* Backgroundpictures (Radio- and File Mode) could be displayed as a Screensaver. Fileformat is the same as the @bexbier Screensaverplugin format
* Backgroundpicture can be switched off (Plasma-Fix)
* Dreamnetcast with Streamripper (direct recording from the server and automatic conversion into mp3 File format
* Upnp Client and Server (available for DM500 - DM7000 as a Addon from our Server)
* The Position of the Infobar can be changed without editing the Skinfile
* Dropbear are now switchable (DM500 - DM7000: Standard->off)
New:
* fuse update from 2.6.1 up to 2.6.3
* libupnp update from 1.4.1 up to 1.4.3
* ushare update from 0.9.8 up to 0.9.10
* streamripper update from 1.61.3 up to 1.61.27
Fix & Update:
* see CVS
* upnp
IMPORTANT:
* The ever last Gemini Image for Dreambox Models: DM56x0
Special Characters will be displayed now
Full ts support from upnp Server
