ג'מיני אניגמה 2 1.90
הודעות: 30816
Gemini2 v1.90:
Technical Infos:
* Engima from: 02.11.06
* GCC 4.1.0 Original CVS
* Busybox 1.2.2
* Kernel 2.6.12.6
Function Buttons:
* BLUE - Blue Panel (BP)
* RED - Record
* GREEN - Subservices
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Support for CDROM/DVD, no matter if IDE or USB port
* Display of current channel stream rates
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* Storage location of epg.dat can be changed via menu
* Display of CaIDs via Infobar
* Password can be changed via menu
* Autocamd
* camd scricpt can be edited
* HDD performance
* Weather Plugin with 10 days forecast
* RSS/RDF reader with TOP list from RSS-scout
* Active PiP
* Blue Button with following functions: 1 x (short) Blue Panel, 2 x (short) Blue Panel -> Extras/Settings, 1 x (long) blue PiP
* The image does now contain a useraddon.xml in /etc to enter an own addon server which will additionally be displayed in download menu. The file actually contains a example.
* Nemesis skins
* Installation of addons via browser
* IPK can be choosen and installed via browser
* Installation of plugins without Enigma restart
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Picicons via Blue Panel
* True automount, examples in /etc/automount.conf. Devices, NFS or CIFS get mounted automatically and also erased if they are not in use for longer than 2 minutes (only working if the kernel of Gemini 1.8 is in use)
New:
* CD/DVD routines revises
* automount.conf - Entrys can be modified with the BP-Menu
* Example of "htaccess" for "little Apache" added
* 3x5c9 Enhanced Webiface added (THX for your work)
להורדה
