kernel 2.6.9 from cvs 22.7.2006 VAR , 3MB
- BusyBox v1.01 (2006.07.23-08:55+0000) Built-in shell (ash)
+ telnet client and some others (only for missed telnet client )
- Dropbear multi-purpose version 0.44
rsa key is generated to /var/etc/dropbear/dropbear_rsa_host_key
after restart
- ssh client (dbclient) ssh root@192.168.x.x
- smbmount.sh added for mounting of the samba servers
for this only remove # from line sleep 15 && smbmount.sh > /dev/null
and make changes in /var/bin/smbmount.sh for ip of the samba
server , password and sharedir
- added GP bootlogo
- possibility use own bootlogo
from /var/tuxbox/config/enigma/pictures/mylogo
- added directories for crond /var/spool/cron/crontabs
for your own aplication set start of the crond from /var/etc/init
(uncomment line sleep 15 && /var/bin/crond &)
set /var/spool/cron/crontabs/root with your app
- prepared for Midnight Commander 4.61 addon
- fixies : added little apache to busybox for function from gemini menu -
not function properly in modifi version before
added CIFS 1.44 prepatch to kernel - missed in versions before
For instalation from maxvar (modifi) versions before use root.cramfs + factory reset or dreamup.
For instalation from another versions it's better to use dreamup.
MD5 : 47AFD4F8A607B8CE89B6CBB83D4FBDDA gemini300maxvar_db500.img
+- 4 960 256 bytes
/************This are only small modifications , it's Gemini team image and thanks for their work.**************/
