WCE 1.0.4_S2
Seca2 interim release
Decodes Sky Italy (0070) on hotbird using a conax 4.0 cam or
a freecam (limited sucess though)
"Normal" channels should work, PPV's possibly (depends on receiver's ability to select ECM_PID)
*Interim* means the code used is just temporary, it use external Titanium EEPROM file (inluded)
and to much is hardcoded
so better to release than wait
To use (in conax 4.0 cam):
Set Conax as defaultmode, seca as defaultconaxmode (from .ini or from 'x' menu)
for freecam 2020 works.opens only all sky(13e)
just in goodies meniu enter this plain key
083 069 000 112 000 113 000 114 000 000
its already calculated into decimal.
