36E, 11140H, 26500, 7/8
Program Number: 1 ARQIVA HD UKI694
Descriptor: Maximum Bitrate Descriptor
Maximum bitrate: 5342150 bytes per second
Descriptor: Smoothing Buffer Descriptor
SB Leak Rate: 625 SB Size: 1024
Descriptor: System Clock Descriptor
External Clock Reference: 0 Clock Accuracy Integer: 2 Exponent: 1
Stream Type: 0x02 MPEG-2 Video PID 308 (0x0134)
MPEG Video: Bitrate 34.966 Mbps Resolution 1920 x 1080i
MPEG Video: Framerate 25 fps Aspect Ratio 16:9 Chroma Format 4:2:2
Descriptor: Data Stream Alignment Descriptor
Alignment type: video access unit
Stream Type: 0x06 PCM Audio PID 256 (0x0100)
Descriptor: Registration Descriptor
Format identifier: 0x42535344 (BSSD)
Descriptor: ISO639 Language Descriptor
Language: eng
Audio type: undefined
Stream Type: 0x06 PCM Audio PID 257 (0x0101)
Language: eng
Stream Type: 0x04 MPEG-2 Audio PID 258 (0x0102)
MPEG1 Audio: Bitrate 384 Kbps Sample Rate 48 KHz
MPEG1 Audio: Layer II Mode Stereo
Language: eng
Stream Type: 0x04 MPEG-2 Audio PID 259 (0x0103)
Language: eng
