סוגים שונים של צלחות ואנטנות לקליטת לווינים:
- איש המציאות
- הודעות: 792
- הצטרף: 23 דצמבר 2003, 09:33
- מיקום: חיפה
1) Offset antenna
2) Prime focus antenna
3) Flat antenna
4) Cassegrin antenna
5) Multi focus antenna
Offset antennas
These antennas represent just a part of a parabolic or prime focus antenna. Their focus is not in the geometrical centre of the dish but a bit lower. Since the LNB doesn’t stand in the way of the signal these antennas can be smaller than others.
Prime focus antenna
Prime focus antennas have a parabolic shape and characteristic is that the focus is in front of the centre of the parabola in the geometrical centre that is. That means if the LNB is attached to this antenna it can be found above the middle of the antenna and so the LNB blocks a part of the emitted signals and therefore these antennas have to be bigger than offset antennas. Offset antennas replaced these antennas nearly completely. Today they are mostly used for the reception of signals in the C belt, since these are the only antennas that are built in scopes up to 10m.
Cassegrain antennas
These antenna with two reflectors receive signals better. It looks like normal prime focus or offset antenna with the exception that in the place of the LNB is an additional reflector, which has the task to reflect signals coming from the main reflector onto the LNB, which is now placed on the LNB-carrier in front of the small reflector. This means the signals are reflected twice before they get to the LNB.
Flat antennas
This antenna is made of many units, which receive signals, afterwards this received signals are united and directed to the LNB. Technically speaking this antenna collects electromagnetic waves. Since this antenna receives through several units it receives a stronger signal. This antenna can be smaller than advised for several areas.
Multi focus antennas
These antennas are made not long ago. They are offset antennas, which have a specially built reflector, which reflects received signals from surrounding satellites to one focus. You can recognize such an antenna easily, since it quadratic and it’s longer than wider.
Gregorian dish
A subversion of satellite antenna that uses a concave hyperbolic
reflector that points signals to the converter and that is placed
opposite of the main reflector. An elliptical Cassgrain.
The Torodial
An offset antenna using a Cassegrain, multi focus feed system
3) Flat antenna
Offset antennas
Prime focus antenna
Cassegrain antennas
Flat antennas
Gregorian dish
The Torodial
my collection so far :
- איש המציאות
- הודעות: 792
- מיקום: חיפה
אפשר גם אפשר ...!
בעתיד אני מתכנן לתרגם את כל המאמרים כאן לעיברית ...
(אני צריך רק קצת זמן חופשי בשביל זה)
אמיר.
אמיר.
lorry
- הודעות: 475
- הצטרף: 20 פברואר 2004, 13:54
- מיקום: London
geostant
- הודעות: 1037
- הצטרף: 23 ינואר 2004, 15:28
- מיקום: אינו מוגדר
- sateyes
- הודעות: 677
- הצטרף: 24 דצמבר 2003, 17:29
- מיקום: עמקים
- משה גמ
- הודעות: 1242
- הצטרף: 23 דצמבר 2003, 00:44
- מיקום: חיפה
הנה התרגום פחות או יותר למה שאמיר איש המציאות כתב=
1) אנטנת היסט
2) מוקד מובחר אנטנה
3) אנטנת שטוח
4) Cassegrin אנטנה
5) מוקד מרובה אנטנה
אנטנות היסט
אנטנות אלה מליצגות רק חלק של parabolic או מוקד מובחר אנטנה. המוקד שלהם לא במוקד הגיאומטרי מהקערית אבל בית יותר נמוכה. מאחר הLNB לא שולחנון בדרך מהאות אנטנות אלה יכולות להיות קטן יותר מאחרים.
מוקד מובחר אנטנה
למוקד מובחר אנטנות יש parabolic צורה ומאפין זה המוקד בקידמה מהמוקד מהפרבולה במוקד הגיאומטרים ש. ממוצעים אלו אם הLNB מוצמדת לאנטנה זאת שזה נכול להיות מצוא מעל האמצעי מהאנטנה ולכן הLNB בלוקים חלק מהנפלט אות ולכן אנטנות אלה צריכות ליותר גדולות מאנטנות היסט. אנטנות היסט הוחלף אנטנות אלה מושלמות כמעטות. היום הם משתמשים עלים פים רובים עבור הדלפק קבלה של אות בנחגרות, מאחר אלה הרק אנטנות שטווחים בנוים למעלה ל 10m.
Cassegrain אנטנות
אנטנה אלה עם שני מחזירורים מקבלים אות יותרות טובות. זה דומה למובחר רגיל מוקד או אנטנת היסט עם החריג שבהמקום מהLNB מחזירור נוסף, איזה המשימה לאות להרהר הבאות מהמחזירור ראשי על הLNB, איזה כעת ממוקמת על הLNB-carrier ב קידמה מהמחזירור קטן. ממוצעים אלו האות reflected לפני שפעמיים שהם מקבלים לLNB.
אנטנות שטוח
אנטנה זאת ניעשית של הרבה יחידות, איזה מקבלות אות, אחרי כן אות התקבלות אלו וdirected מלוכדות לLNB. טכנית מדברת אנטנה זאת אוספת גלים אלקטרומגנטים. מאחר לקבל אנטנה אלו דרך מספר יחידות שזה מקבל אות יותר חזק. אנטנה זאת יכולה להיות קטן יותר מהודיעו עבור מספר אזורים.
מוקד מרובה אנטנות
אנטנות אלה ניעשות לא לפני ארוכות. הם אנטנות היסט, איזה בנה מחזירור מיוח, איזה להרהר אות התקבלות מים לוויני הקיף לאפס מוקד. אתה יכול לזהה כמו אנטנה easily, מאחר שזה יותר ארוך של ריבועי וזה מרוחב.
קערית לועזי
ערעור של אנטנת לווין משתמש מוגזמת קעורה זאת
מחזירור שמצביע אות לממיר ומיקם זה
ממול מהמחזירור ראשי. Cassgrain סגלגל.
הTorodial
אנטנת היסט משתמשת Cassegrain, מוקד מרובה מזין מערכת
_________________
האוסף שלי לכן הרחק :
ממשק עונה
skystar22
מטר אות אנלוגי
אינסוף usb
manhattann
קרח שחור
מטריצה reloaded
funcard מתכמת
עכבר חכם
1.60 קערית
1.80 + "24 מממש
רכב - Sirius® Satellite Panasonic MP3/WMA
נערך בפעם אחרונה על-ידי איש המציאות בתאריך 23/02/2004 ב- 18:56:30, נערך סך הכל פעם אחת
חזור למעלה
1) אנטנת היסט
2) מוקד מובחר אנטנה
3) אנטנת שטוח
4) Cassegrin אנטנה
5) מוקד מרובה אנטנה
אנטנות היסט
מוקד מובחר אנטנה
Cassegrain אנטנות
אנטנות שטוח
מוקד מרובה אנטנות
קערית לועזי
הTorodial
_________________
ממשק עונה
skystar22
מטר אות אנלוגי
אינסוף usb
manhattann
קרח שחור
מטריצה reloaded
funcard מתכמת
עכבר חכם
1.60 קערית
1.80 + "24 מממש
חזור למעלה
- איש המציאות
- הודעות: 792
- מיקום: חיפה
