גמיני 2.70
Gemini v2.70:
Technical Infos:
* Enigma of: 26.01.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.2-Expert
* Busybox 1.01
* Tuxtxt V1.96
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own Addon-Server via internet.
* AutoCam: Emus can be linked to channel/provider
* Cam-Settings: For example renaming of emus, Multichannel-Patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini News in background
* JPEGs can be rotated and the EXIF-Tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random - function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if they use a IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside the box,
the Mountpoint set to "/mnt/usb" and at least 3GB)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Dreamnetcast: with Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be choosen via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* The Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabian
* EPG for Dishnetwork
* 2 new entries for music and pictures can be created in root of the filemenu (BP->Extras/Settings->Root-Entry)
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD) FAQ can be found in the database
* Alarm Clock with volume offset adjustable playing your own WAV-files.
New:
* Configfile for calendar changed to XML
Fix:
* Printserver (memory bug)
* Root-Entry of Extras/Settings for boxes < 7020
* Display of new messages
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" Thread.
Unfortunatly many things can not be realized from our side.
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16MB) should be present if several processes running in backround.
להורדה
