Gemini v2.50:
Technical Information:
* Enigma:20.11.2005
* GCC 3.4.4 Original CVS
* Web Interface: 5.7.0-Expert
* Busybox 1.01 ( <=7000 )
* Busybox 1.00 ( ==7020 )
Button Functions:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/SETTINGS
* YELLOW - Quick-Button (CAN BE ADJUSTED OVER BLUE PANEL)
* RED - EPG List FOR CURRENT CHANNEL
* 2x RED - EPG Style Menu
* GREEN - Subservices
Features:
* Own Addon-Server via Internet.
* AutoCam: Emus can be linked to Channel/Provider
* Cam-Settings: for example Renaming of Emus, Multichannel-Patch adjustable ( >=7000 )
* OSD: EMM- and ECM- Display adjustable
* Possibillity of download and automatical install of extra Functions via Internet from the Gemini -Server
* System Info: Many exrta infos about your Box (for example Harddisk-Temperature or all other Enigma-Settings)
* Gemini-News are loaded in the backround
* JPEGs can be turned and the EXIF-Tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random - Function for MP3 and OGG
* Quick-Button-Menu: Many extra Functions for the yellow button
* smbmount
* Support for CDROM/DVD, doesn't matter if IDE or USB ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted Harddisk (only possible if no Harddisk is present in the box,the Mountpoint has to be "/mnt/usb" with a Minimum of 3GB)
* Extra Menu: Settings for many Extras like Inadyn, HTTPD, EPG-Cache, setting var to usb/hdd and many more
* Backup Function
* Dreamnetcast: with Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be chosen over Blue Panel.
* Custom Scripts can be started over Blue Panel
New:
* Calender including Reminder (can be changed over .../gemini_cal.conf)
* Possibillity to reroute Syslogd + Enigma-Debug-Messages to Syslog
* Menu to change the Password.
* Process-Info & Memory-Info in System-Informations
* BP has a new style
* Enigma-Settings in Sysinfo-Folder with Delete-Function
* MHW-EPG from CVS is activated
להורדה
