PRONT PANEL TPRIL DRAGON
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
פנל של טריפל דראגון
sateyes
הודעות: 677
הצטרף: 24 דצמבר 2003, 17:29
מיקום: עמקים
שליחה על ידי sateyes »
m8m8,
אתה יכול לפרט יותר על המקלט הזה.
m8m8
הודעות: 11160
מיקום: home
מפרט טכני
שליחה על ידי m8m8 »
BOX Teil 1:
- 250 MHz IBM PowerPC Processor (350 Mips)
- 80 MByte RAM
- 8MByte Flash
- 1 x DVB Common-Interface Slot
- 2 x Smartcard reader (2 x Conax embedded or Conax/Seca)
- MPEG2 Hardware decoding (DVB kompatibel)
- ready to support MPEG4
- MP3 hardware decoding
- DVB-S, DVB-C and DVB-T models
- 100 MBit full duplex Ethernet Interface
- USB connector for keyboard, mouse, foto camera, etc.
- graphical LC-Display
- built-in IDE UDMA66 master/slave connector
- supports all standard harddisks
- S/P-DIF optical out for PCM / AC-3 / DTS
- video connectors:
- 2 x SCART
- 1 x Composite
- 1 x SVideo
- 1 x 12V software controllable switch
- Linux based
- hardware assisted display of pictures (photocd, foto camera, etc.) on TV
- unlimited channellists
- very fast and smooth channel switching
- fast and completely automatic channelsearch
- unlimited bouquet/favourite lists
- DVB EPG support
- EPG support for non-DVB channels (MTV, CSAT (france), etc.)
- teletext support
- Web browser, email client
- support for DiSEqC 1.0 1.1 1.2 2.0
- multi language OSD
BOX Teil 2:
- integrated 6 in 1 Compact Card Flash reader
- built in harddisk, currently 80 to 120GB
- built in DVD Recorder supports DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW
- timeshifted recordings
- trick replay (fast forward, rewind, slowmotion, instant replay)
- start recordings through: timer, epg, quick start
- recordings are accessible to any PC connected to the same network as
the receiver
- copy recordings from harddisk to DVD
- DVD-Video conforming (enables playback in any DVD player)
- create SVCDs from recordings on harddisk
- playback of DVD Video & SVCD
- playback of CD audio, including CD Text support
- playback of MP3 CDs
- Kodak Picture-CD and Photo-CD support
- allows creation of backup copies of Video DVDs & CDs (Audio CDs, etc)
- the DVD recorder inside the box is shared through the ethernet in a
way that every PC can use it as if it was built directly into this PC
(allows recording to DVD from the PC)
Box Teil 3:
- Dolby Digital (AC-3) 5.1 Multichannel Decoder
- Dolby Digital (AC-3), Dolby Pro Logic, and Stereo Mode
- Maximum, Standard, Late Night Dynamic Range Compression Mode
- Precision Digital Output Volume and Mute Control
- Precision 96KHz/24bit ADC and DAC with Lowpass Active Filter
- EEPROM Setup Status Memory when AC Power Shut Off
sateyes
הודעות: 677
מיקום: עמקים
זו באמת חיה רעה!!!
מה השוואה לדרימבוקס?
מה מחירו?
יש לו תוכנות לשיתוף ופריצה?
|upset|
m8m8
הודעות: 11160
מיקום: home
תכונות מקלט
שליחה על ידי m8m8 »
מקלט זה יותר מאפשר להקלט סרטים DVD RW
יש לו יציאת SCSI
שאין בדריםסוקס
מחירו יותר גבוה
עובד על תוכנה מקורית ללא PATCH
