גירסה ל 7020
Gemini Image 2.40 (Dream 7020):
Technical Information:
Enigma of 19.10.2005
gcc 3.4.4 Original CVS
Web Interface: 5.3.0-Expert
BLUE Button - Blue Panel
2x Blue Button - Set boot/mode Pictures via BluePanel
YELLOW Button - Quick-Button (can be assigned via Blue Panel)
AUDIO Button - Sound track choice
TEXT Button - Video Text
RED Button - EPG List for current channel
2x RED Button - EPG Style Menu
GREEN BUTTON - Subservices
Features:
Cam:
* AutoCam: Assign Emus to channels/provider
* CamName: renaming of Emus
* Multichannel-Patch switchable via Cam-Settings
OSD/EPG:
* OSD: EMM- and ECM- Display
* Epg-cache: Saves EPG-Data on HDD or USB-Stick
* permanent clock on OSD (may be assigned to Quick-Button)
Addons:
* Additional Features available via Internet from Gemini-Server with auto installation
* DreamInfo: many additional Information of your Box (i.e. HDD-Temperature or all Enigma-Settings)
* MP3: Random - Feature
* Gemini-News will be loaded in a background process
* JPEGs may be rotated and EXIF-Tags can be shown
* Support for OGG/Vorbis
* Random - Function for MP3 and OGG
Technics:
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB (not for 5620 or 500)
Recording:
* Record CIFS: Record to a HDD mounted with CIFS (will only work, if no HDD is inside the Box)
* Record NFS: Record to a HDD mounted with NFS (will only work, if no HDD is inside the Box)
Setting Features:
* Extra Menu: Settings for lots of Extras like Inadyn, HTTPD, EPG-Cache, Swap out VAR and many more
* Backup-function
* Quick-Button: Freeze Image or zap to a predefined channel
NFS/CIFS is only available in Timer-menu, if mounted successfully. There is a size-check available. If the capacity is more than 3GB (NFS/CIFS Mount) and /mnt/hdd is bigger than 3GB, it will be shown in the Timer-Menu (this works only without internal HDD!)
Please mount PC-HDD always to /mnt/hdd
NEW:
* lzma_patch
* Entire Blue Panel is outsourced
* Record SMBFS: Recording to a HDD mounted with Samba on a PC
* Dreamnetcast: Extended with Shoutkast TOP(100)
* Infobar: Settings expanded
* Background-Pictures: for Radio, MP3 and SCAN can now be chosen via Blue-Panel.
* Backup Creation: personal Blue-Panel addons can be saved
* Backup Rebuilding: personal Blue Panel addons-Settings can be rebuilt
We wish to thank all people, that supported us on the recommendation-Thread for the Gemini-Image.
Unfortunately lots of things are not possible from our side.
להורדה
