* webif 3.1.0
- integrate grabpic code (grabpic is no longer required)
- show osd shot together with remote control to improve navigation
- only refresh leftnavi when required
* only don't compare data[0] (dvb service type ) when service flags are zero ( real tv/radio services )
* enigma_standby.cpp: small fix ( rezap after standby )
* upgrade.cpp: fix
* skin blueqt: add 2 missing files
* scan.cpp: fix wording
* webif 3.2.0: improved streaming with vlc
* carbon skin: bigger font
* fix memleak ( thanks to LittleBoy )
* enigma_dyn.cpp: enable translation for littleboy ;-)
* fix rc defaults
* fix seek back from normal tv mode with running recording ( start timeshift )
* do not restart enigma after change skin, when a recordings is running
* support for pngs with non 8bit
* bigger record buffer
* optimize picture sizes ( much smaller ) thanks to LittleBoy for enigma changes and reducing tool
להורדה כאן
Orginal/CVS 7000 Image
גרסת עדכון
* dont show epg.dat in filebrowser
* add another cyfra+ transponder to two byte mapping list
* remove debug messages during clean loop..
* fix ePtrList::insert_in_order funktion and use it in eMainloop instead of call sort() after every insert
* webif: little fix for external message (got beaten up too much ;-)
* implement missing private_data_specifier descriptor,
small fix
* section timeout handling fixes
* timer subservice/event_id handling fix
* webif: remove \n from epg in zap list
* implement /control/zapto/getallpids .. for neutrino compatibility
* replace "\n" width " - " in event_name in short event info descriptors.. thanks to Tele 5 for this bullshit großes Grinsen
* revert to old rc style, short press starts tuxtxt and holding the key opens the plugin list
* webif: add ref parameter to ../xml/epg function to allow the specification of a service reference
* webif: fix xml epg function
* webif: xml epg function refinement
* webif: more work on xml functions
* add ALL audio pids to xml file
* add ALL audio channel name to xml file, as well
* change encoding to utf-8
* webif: allow enablinge/disabling of osd shot after remote control keystroke
* remove unneeded compile switch
Incl:
- add support for private epg
- some language (English, Deutsch, Spanish, Suomi, French, Hungarian, Italian, Dutch, Polish and Turkish)
- some games (Pacman, Snake and Tetris)
- Simple EUROPE Satellites_XML by Reinh@rd from 13.06.2005
- all Skins
CAREFULL:THIS IMAGE CONTAINS THE FP.1.06,THIS VERSION CAN'T BE DOWNGRADED,SO THINK ABOUT IF YOU REALLY NEED( POSSIBLE REASONS:MAYBE CAUSE YOUR BOX HAS PROBLEMS WITH THE FP. 1.05)BEFORE UPLOADING IT TO YOUR FLASH!
להורדה כאן
small fix
Incl:
- all Skins
להורדה כאן
