מסך פלזמה
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
לוויון NIMIQ 91W הניקלט בקנדה שידור ב C BAND
הדגמה על דרים 7000S
ניתוני מסך פלזמה
Panasonic TH-37PD25U/P 37" Flat Panel Plasma TV
Color: Silver with black trim
Screen size: 37 inches
TV type: Gas-plasma
HDTV capable: Yes (480p, EDTV resolution)
Aspect ratio: 16:9
3:2 pulldown detection: Yes
Speaker wattage per channel: 8 watts x 2 (into 6 ohms, from 105 to 20,000 Hz, with 10 percent THD)
Number of speakers: 2
Ports: SD Card and CableCARD
Includes radio: No
Comb filter: No
Line doubling: No
Noise reduction: Yes
Signal type: NTSC, ATSC (480p)
Black-level expansion: Yes
Picture enhancements: New Real Black Drive System, Gamma Enhancement System, Mach Band Effect Enhancer
Picture modes: Video-input picture memory
Input labeling: Yes
Closed captioning: Yes
Mute: Yes
Multilingual menu: English only (disc menus may be different)
Parental control: Yes (V-Chip)
Picture-in-picture (PIP): Yes (2-tuner, scalable, split-screen with channel search)
Remote control: Yes
Sleep timer: Yes
Surround sound: Yes (BBE ViVA HD3D Sound, simulated from 2-channel programs)
VGA/SVGA input: 1 (front-panel)
Audio outputs: 1 stereo analog (left/right) RCA
Audio inputs: 5 stereo analog (left/right) RCA
Video outputs: 1 (composite-video)
Video inputs: 10
Headphone jack: Yes (.125-inch, front-panel)
Digital video input: 1 (HDMI)
Component video: 2
Composite video: 3
S-video: 3
RF: 0
Monitor: No (includes NTSC and ATSC tuners)
Pixels: 852 x 480
Contrast ratio: Up to 4,000:1
Brightness: Information not available
Brightness gradations: 1536
Dot pitch: 0.96 x 0.96 mm
Colors: Over 1 billion (1,070 million)
Horizontal viewing angle: Information not available
Vertical viewing angle: Information not available
Response time: Information not available
Lamp life: Information not available
Front AV jacks: Yes
Sound leveler system: Yes
Wall mountable: Yes
Power supply: AC 120V, 50/60 Hz
Power consumption: Information not available
Energy Star compliant: No
Environmental: 0 to 40 degrees C; 20 to 80 percent humidity (non-condensing)
Approvals: UL6500/C-UL
Item width: 42.1 inches
Item height: 23.5 inches
Item depth: 3.9 inches
Item weight: 67.2 pounds
Warranty: 1 year parts and labor
In the box: TV, remote control, remote batteries (2 AA), a pedestal base, an AC power cord, F-type coaxial antenna adapters, ferrite cores, 2 clampers, a warranty card, a customer card, and a service-center list
